cab clearance lights - Ford Powerstroke Diesel Forum
Old 10-25-2007, 01:00 PM
ok, I've ordered the wire harness and lights from Ford and also purchased the smoked lenses from Recon. The wiring is fairly simple but the kit did not come with any sort of template for drilling the holes through the roof. Is there any sort of marking inside the cab once the headliner is lowered? Have any of you guys installed the clearance lights yourselves? I'm sure I can make my own template but just want to be prepared once I start the project.
Scott
Old 10-25-2007, 05:10 PM
from what i know their is nothing under the headliner... you will have to make your own template... easiest way is find a friend that already has the cab lights and make a template off of his... get some construction paper (the kind you cover windows with when you paint) and mark the curvature of the front window and where the doors meet... next mark where the cab lights are installed... and transfer all that to your truck..... hardest part is deciding to drill your roof lol....
-Raul
Old 10-25-2007, 05:14 PM
International Threat
Biggest issue is the drilling!
Just measure about 10 times and drill once! Remember if you screw up you have an inch each way to go b/c the cab lights will cover it.
Old 10-25-2007, 05:18 PM
Here is what they look like when you take the cab lights off...
Old 10-25-2007, 05:26 PM
install
Did some one do write up on the install? and the smoke ones look great.
Old 10-25-2007, 05:31 PM
Yeh... there is one... it's on a bronco site...
vitalidle is usually ON these things... I know he's got the link LOL!
If you do a search for cab light install on here I'm sure you'll find it!
Old 10-25-2007, 05:35 PM
Ah_Ha!
GOT IT!
Motoman's Madness
Old 10-26-2007, 04:23 AM
Gun Nut
I was going to do a write up but never did. It's easy just take your time and like the guys mentioned - measure, measure, measure. Nothing like taking a hole saw to the top of your rig.
Let me know when you're going to do it, I can give you my # so you can call if you have any questions.
Old 10-26-2007, 05:12 AM
Thats what we did when installing my brothers light. We measured off my truck and marked his then drilled away.Just incase you didnt know the harness connector is on passenger side behind kick pannel.
