pulling the turbo right now and ... - Ford Powerstroke Diesel Forum
Old 11-09-2012, 04:06 PM
Holyhell is this thing stuck! How do you properly pry it out?
I've bent 2 pry bars now. Just 2retaining bolts right?
Old 11-09-2012, 04:10 PM
MAD - Modification Addict
Feedback Score: 7 reviews
3 bolts.. One on each side in the front bottom and one in the back of the turbo under the down pipe.
Old 11-09-2012, 04:11 PM
Feedback Score: 3 reviews
3 retaining bolts, one in the back. The 03-early 04 turbo bolt is blue circle, the late 04-07 is red circle.
Sent from my iPhone using Autoguide.com App
Old 11-09-2012, 04:15 PM
Send a message via Skype™ to Bluedemon6.0
It sucks. I used a small pry bar and a screw driver. Walk away and go back to it. There is no trick just patients. A 90 degree screw driver might help.
Sent from my PG06100 using AutoGuide.Com Free App
Old 11-09-2012, 04:19 PM
No there are three if it is an 04-06 pedistal. There is a bolt in the back side of the pedistal. I thought you meant the pipes. The turbo should come right off with all 3 bolts out.
Old 11-09-2012, 04:28 PM
There are 3 bolts regardless of the year of engine. Only the bolt orientation changed from the 03 and early 04 6.0's to the 04.5 - 2007 6.0's.
Old 11-09-2012, 06:40 PM
definately is 3, did this same thing for about an hour and thought to myself well time for another case of beer, came back from the store and the third bolt location was shiny like a night in armour in the sunshine, boy did i feel like a ratard.
Old 11-09-2012, 06:59 PM
Just wait until that back bolt rounds off! Lol
Before you round off the bolt, work the turbo up and down by prying up over by the egr cooler then push back down repete. That will help loosen the back bolt.
