Wheel/Tire Size question..... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-09-2012, 08:54 AM Thread Starter
Hey fellas please help a brotha out! I've searched this forum for hours and can't find exactly what I'm looking for.
Im in the market for new wheels and tires for my 06 250. I'm going to put a 2.5" leveling kit up front and need to know what tire I can fit and what offset I need to get on the wheels.
Im going into a 20x10 wheel and it comes in either a -12mm or a -24mm offset. I want a toyo 35x12.5 m/t tire to wrap around them. First, will this fit? Second, which offset will be better? I like the look of the tire protruding from under the fender some, but not a ton.
I appreciate the help and advice fellas!
2006 F250 Lariat Crew; Full 4" exhaust, cts, SCT panty dropper (sold)
2013 F250 Lariat Crew
gsujeff55 is offline
post #2 of 6 Old 11-09-2012, 11:53 AM
Galaxie's Avatar
I have a 2" level and run a 35. I have the 06 Harley wheels... No clue on offset.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #3 of 6 Old 11-11-2012, 05:39 PM Thread Starter
Bump for help please!
post #4 of 6 Old 11-11-2012, 06:10 PM
DRILLROCK's Avatar
My 05 F-350 with 2 1/2" front level kit. Factory rims with 35"x12.50"x18" No rubbing, No issues.
Jeff
2005 F-350 CCLB King Ranch 4 X 4
Airaid cold air intake box & filter
MBRP TURBO BACK 4" Exhaust
2 1/2" Rancho Coil Spring Front Level Kit
ReadyLift TractBar Relocation Mount
RanchHand Front Replacement Bumper
Ride Rite Rear Air Bags
ScanGauge ll
Dieselsites coolant filter
35/12.50/18" 10p Toyo open Country ll
RC Dual Steering Stabilizers
Atlas 40 from Ficmrepair
River City Diesel EGR Delete
Other Rides--06 Ford Expedition limited--96 Jeep Cherokee--08 GMC crew cab
DRILLROCK is offline
post #5 of 6 Old 11-11-2012, 06:41 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
True 35" will rub on your mud flaps on tight turns, but not on the wheel-well, unless your suspension is flexed. For a street truck it will work. If you plan on going off-road, you need at least 4" of lift to be trouble-free. FWIW, the tires in my sig rub on my front flaps when turned tight. I did not expect that, given the tire diameter (just under 34").
A few years ago I posted a picture of 33" tires showing how tight it was up front on a turned wheel with stock or even a 2" front level. Rather than buy first curse later, find someone (friend, shop,etc) that has the tires and wheels on a vehicle and ask to fit one one your front end. Turn your wheels side to side and then imagine the arc of the suspension.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 6 Old 11-12-2012, 01:51 PM Thread Starter
Thanks guys. I appreciate the help.
