bulletproof checklist/advice please - Ford Powerstroke Diesel Forum
Old 11-08-2012, 04:24 PM
Going to get bulletproofed in the up coming months and was looking to start ordering all the components now a few at a time so my wallet wont feel it as much. So far im going with: (BESIDES OEM COMPONENTS)
-ARP studs
-EGR delete (sinister/RCD) which one?
-blue spring update
-4 gallons of CAT ELC coolant
-Sinister coolant filter---should i run a coolant filter with the CAT ELC or just if i continue using gold coolant (im still under warranty) and should i install before or after bulletproofing?
-Should i use restore + with my flush before i send it in? also what coolant should i replace it with between the flush and entering the shop? i dont feel like wasting money on another fillup of CAT ELC if their just going to drain it when they replace the oil cooler.
Thanks
Old 11-08-2012, 04:27 PM
MAD - Modification Addict
Feedback Score: 7 reviews
APR Head Studs: 250-4202 - Let me know if I can help you out with these, stealth automotive $439
OEM Oil Cooler Rebuild kit: 3C3Z 6A642 CA- Order from sunrisefordparts.com $269 shipped
IPR Gen 2 EGR delete kit: SKU: EGD-60GEN2B- iprresearch.com $259.99 + shipping
IPR High Flow Coolant Filter: iprresearch.com $249.00 + shipping
Glowplug harness left side: 4C2Z 12A690 BA- sunrisefordparts.com $40.80
Glowplug harness right side: 4C2Z 12A690 AB- sunrisefordparts.com $40.80
Updated Turbo drain tube: 6C3Z 9T515 A - sunrisefordparts.com $24.37
Updated Turbo Oil feed: 3C3Z 9T516 A - sunrisefordparts.com $87.50
Thermostat: 4C4Z 8575 AA - sunrisefordparts.com $28.60
6.4 Banjo bolts: w302472 Need 2 - sunrisefordparts.com $10.50
6.4 banjo bolt washers: w303659 need 4 - sunrisefordparts.com $3.60
Main drive belt: jk8 1331 a - sunrisefordparts.com $49.82
Secondary drive belt: jk6 664 a - sunrisefordparts.com $25.34
Updated dummy plugs: w302908 - sunrisefordparts.com $24.60
OEM Head gaskets: 6C3Z 6051 AA need 2 - sunrisefordparts.com $271.20, Comes with new updated standpipe, gasket TTY headbolts and head locating dowels. Sunrisefordparts.com*
Water separator updated drain kit: 6e7z 9c082 a - sunrisefordparts.com $12.50
OEM Oil Filter: FL 2016 - sunrisefordparts.com $19.50
OEM Fuel Filter Kit: 3c3z 9n184 cb - sunrisefordparts.com $49.95
Exhaust manifold gaskets: 6c3z 9448 a need 2 - sunrisefordparts.com $21.22
CAC boots both hot and cold side. RIFFRAFFDIESEL.com I paid $140 shipped. If your cold side CAC (intercooler tube) is black plastic than upgrade to the metal one. 6c3z 6c640 aa sunrisefordparts.com $115.08
Injector o-ring kit: 3C3Z 9229 AA need 8 - sunrisefordparts.com $31.68 (if you send injectors to Jesse Warren you don’t need this part)*
Fleetgaurd Restore and Fleetgaurd Restore + cooling system chemical flushes. Can get at local big rig truck dealers (they can order it) usually around $23-$30 a gallon, need one gallon of each.
Zerex EC-1 Rated ELC fully formulated coolant, 1 case* buy it at NAPA Part number is ZXED-1 usually between $13-$20 a gallon times 6 in a case.
Rotella T6 full synthetic oil on sale at TSC (Tractor Supply Company) for $19.99 until the end of october.
I would suggest push rods since it’s apart. 8c3z 6565 b need 16- sunrisefordparts.com $64.80
ARP Ultra Torque Lube 10oz bottle with brush*
ARP 100-9910 Ultra Torque Assembly Lubricant - 10 oz. Brush Top Container : Amazon.com : Automotive ARP 100-9910 Ultra Torque Assembly Lubricant - 10 oz. Brush Top Container : Amazon.com : Automotive
Fumoto quick drain valves for the block plugs F-108N*
Fumoto F-108N Engine Oil Drain Valve : Amazon.com : Automotive Fumoto F-108N Engine Oil Drain Valve : Amazon.com : Automotive
Snap-on torque adapter tool for rear head bolt on driver side. SRD35 $55 + shipping
11/16 12pt 1/2” drive short socket for head stud nuts.
18mm 1/2” drive 6pt socket to remove head bolts.
Blue spring fuel pressure update: 3C3Z 9T517 AG - sunrisefordparts.com $57.60
If I forgot anything I will add it later lol.
Old 11-08-2012, 04:31 PM
JEEZ THAT WAS QUICK! LOL i have the stc fitting/dummy plugs and standpipes already replaced. i just need to know what i would need to buy in addition to a typical dealer HG job.
Old 11-08-2012, 06:20 PM
Stash a few shucks away to check and surface the heads.
Old 11-08-2012, 06:50 PM
Yup i already figured on that forgot to post it.
Old 11-08-2012, 07:11 PM
I just got all this done to my truck. I have the RCD delete and have done a lot of research on different deletes. Looks like you're on the right track, good luck!
Old 11-08-2012, 07:25 PM
Ipr gen 2 egr delete is the best out there.
Old 11-08-2012, 07:38 PM
I'm not sure on your plan for flushing, but if you are going to use restore do it way before the new oil cooler gets installed. Let the old oil cooler catch everything then go in with a new one.
That's a pretty impressive list you got going on there Bryan.
Old 11-08-2012, 07:39 PM
I never said the RCD was the best, I was just telling him which one I got. After researching and talking to guys who've used the different ones on the market, I only heard a few negative things about a couple of them. The IPR and RCD were not one of them. No complaints on either. The RCD was $70 cheaper, main reason for me going that route.
Old 11-08-2012, 07:43 PM
Found a sinister egr delete brand new in box locally on craigslist for $250. Maybe ill see if i can get that one for $200-225
