ball joints - Ford Powerstroke Diesel Forum
Old 11-05-2012, 02:06 PM
ball joints
anything special about taking apart the front hub assem, to take off control arm to access ball joints?
2003 f350 4x4 6.0 diesel
Old 11-05-2012, 02:19 PM
It bolts in from behind, turn wheel to full lock and use a 21mm socket. Reverse installing rotor with 4 loose lugs makes for a handy slide hammer.
I pulled axles with hub/bearing still on when I did my ball joints. Mucho quickero. 2hrs and my front end was stripped down.
sent from a dumb guy with a smart phone
Old 11-05-2012, 02:22 PM
Yeah pretty easy, just can be a little tight and requiring some persuasion!
Old 11-05-2012, 02:33 PM
so lock the hub and unbolt 4 bolts and slide the whole shaft out?
Old 11-05-2012, 02:39 PM
You dont even need to lock it but yes, it will work that way.
I would recommend disassembling the locking hubs and cleaning them. Then repack with grease on assembly. They dont get cleaned enough. They are also not that difficult to work on.
Old 11-05-2012, 02:42 PM
Thanks , saw a u tube video and im going to tackle it
Old 11-05-2012, 05:13 PM
if you have ABS remember to disconnect it,, little sensors are expensive.
