Rancho Rs5000 shocks - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-04-2012, 06:18 PM Thread Starter
PowerstrokeDriver2's Avatar
I really need to change the stock ford "rancho" shocks. they are rusting pretty bad and probably getting worn out. Would these be a good replacement for the crappy stock shocks?
PowerstrokeDriver2 is offline
post #2 of 10 Old 11-05-2012, 11:31 AM
Aretoo's Avatar
I would recommend the Bilstein 5100's. Just changed out the stock ones with these and the difference is amazing. You do not realize how bad the stock shocks are until you put these on.
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
Sinister Coolant Filter
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #3 of 10 Old 11-05-2012, 11:32 AM
Bilstein!! that is my plan as soon as I need them.
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #4 of 10 Old 11-05-2012, 11:32 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 278 Post(s)
Monroe reflex
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #5 of 10 Old 11-05-2012, 02:17 PM
Quoted: 27 Post(s)
I have been "trialing" Rancho 7000 shocks. Threy have been great. I had the Bilstein 5100's before these and can not tell the difference.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #6 of 10 Old 11-05-2012, 06:57 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Okay Ill be the nerd here but we beat the ba-jesus out of our work trucks and all we run is the rancho 5000 and they can and do hold up. Not saying the bilstein wont do better just my opinon.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 10 Old 11-06-2012, 01:21 PM
mudmaster's Avatar
Quoted: 13 Post(s)
I bought some Rancho 7000s, but haven't installed them yet..............
2004 F350 FX4 6.0 60,300 miles
Banks air intake, Rubicon Express 2.5" leveling kit, 325/65X18 Goodyear Duratracs on 18X9 Metal Mulisha wheels, Dieselsite coolant filter, ScanGauge II, Steel Cold Side Intercooler Tube, Mishimoto boots, 08-12 side mirrors, billet grill, BPD's oil fill cap and oil and filter caps, EGR delete, Autometer fuel press, trans temp and EGT pillar gauges, Solid front diff cover, 08 rear diff cover, Mishimoto intercooler, more to come.............
mudmaster is offline
post #8 of 10 Old 11-06-2012, 01:47 PM
I'm considering RS5500s in the rear. The nitrogen charged Rough Country shocks are way too stiff. Up front they're fine, esp bouncing through the desert.
sent from a dumb guy with a smart phone
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 10 Old 11-06-2012, 01:51 PM
ZMANN's Avatar
Quoted: 1905 Post(s)
RS9000XL Series Shocks
adjustable so you can get away from the harsh bilstein
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #10 of 10 Old 11-06-2012, 02:14 PM
turbotibbo's Avatar
i have these but how do i adjust them there is a little red dial on them but it will not move do i need to jack it up or something and what do the numbes mean 9=firm and 1 = soft ?
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
