Tell me what you think - Ford Powerstroke Diesel Forum
post #1 of 18 Old 11-04-2012, 04:29 PM Thread Starter
Ford 6.0 White Smoke - YouTube
That is the link to my truck smoking. I really am not sure where the white smoke is coming from. The reason there is no whistle is because this is a non vgt turbo. I just had new head gaskets installed 100 miles ago. The injectors got reworked by Warren diesel. My fuel pressure is 64 psi, my ficm is 48v lowest it gets is 47.5. The egr has been deleted. What could be causing this?
The truck runs very strong, it will break tracktion at 45 mph if i stomp it. It seems very responsive and has plenty of power. The smoke really annoys me and I hate seeing it there. I would really like to find a way to clear it up some. Thanks
2004 F250 CCSB FX4
ARP Head Studs, EGR deleted, Sinister bypasss, Cts by Edge, 180/75 by Warren, 62/80 II paht Shaft, Custom Built trans with TransGo Shift kit, Fass 150, S&B Intake, SCT by ID and GH, 4" MBRP turbo back......BlackOut
jamerman09 is offline
post #2 of 18 Old 11-04-2012, 04:35 PM
don't ram it, stroke it's Avatar
Was this on cold start up? Does it smoke even after warmed-up? Are you losing (level dropping) coolant from the degas bottle?
don't ram it, stroke it is offline
post #3 of 18 Old 11-04-2012, 04:36 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
White is usually coolant but its probably grey which is normal.
Sent from my SPH-L710 using AutoGuide.Com Free App
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #4 of 18 Old 11-04-2012, 04:40 PM Thread Starter
it was on a cold start up, it takes 15-25 minutes for it to clear up. I will have to monitor the coolant over the next few days. If it is coolant what would be the cause?
2004 F250 CCSB FX4
post #5 of 18 Old 11-04-2012, 04:44 PM
Mitch
thebierguy's Avatar
Quoted: 89 Post(s)
What was the temperature outside at time of startup? How cold did it get the night before? I don't have a 6.0, but it was 17 degrees here this morning and my 7.3 blew greyish smoke until it warmed up. Normal when it gets cold out. I'm guess that is what is going on for you as well.
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #6 of 18 Old 11-04-2012, 04:46 PM
Galaxie's Avatar
Looks like a cold start to me.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #7 of 18 Old 11-04-2012, 04:50 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
my truck hazes at cold idle regardless of outside temp. I don't know why but it bothers me too. I know it's injector related but it may be impossible to know which one
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 18 Old 11-04-2012, 04:52 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
It's normal.... If I pull the pigtail off of my VGT turbo when idling it will do the same thing. I also have 175's I don't know what you have on yours. But this is normal. Even at idle if the turbo isn't spooling a little bit even the .4 psi to 2 psi at idle than it won't have enough air to clean up the smoke with larger injectors and a big tune.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 18 Old 11-04-2012, 05:15 PM
Perfectly normal...White smoke is normal on cold starts.....But white smoke in a warmed-up diesel is not... and nearly always ties to excess moisture. And would be from an internal source like the cooling system. If you where to notice a regular drop in the coolant level, you would likely have a head gasket/oil cooler/EGR problem.....But if it only does it on cold starts, your good.... let her warm up before you rip it up...haha
post #10 of 18 Old 11-04-2012, 05:30 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
If you have fuel in coolant you don't have bad head gaskets you have a cracked head.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
