black smoke when shifts and turbo pitch change - Ford Powerstroke Diesel Forum
Old 11-02-2012, 10:07 PM
okay well when my truck shifts some times it smokes black smoke not a ton but alot more then stock trucks will smoke if you know what i mean. and then when in overdrive and i get on the peddle, not enough to shift, but enough that the turbo will spool up i can hear the turbo whistle and the pitch of the whistle changes some and then the truck will start to surge and blow a little smoke black smoke when it surges. any ideas whats going on? thanks fellas.
Forgot to say this is when the truck is stock, i havent had the tune on the truck in a while so its been stock for a while and im not getting any codes.
Old 11-03-2012, 05:01 AM
Torn/busted cac boots, exhaust leak, egr clogged/dirty.
Sent from my phone that somebody didn't help me get.
Old 11-03-2012, 05:42 AM
War is the answer!
Trouble threads should always start with engine codes and monitoring information. If it was a cac boot you would have no boost.
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 11-03-2012, 08:41 AM
i dont have any codes, sorry i forgot to put that first but i edited it and added it at the end. all number on my cs look good as far as temps and ficm volts and icp and stuff. and its very intermitent some days it does this some days it doesnt.
