fuel pump issue... - Ford Powerstroke Diesel Forum
Old 11-02-2012, 05:02 AM
fuel pump issue...
While making a turn today my truck felt just like it did when the egr valve stuck. No poweer off idle like it had no fuel. So I figure the fuel pump is dying, will check pressure to confirm shortly. Question is that tousely lists two fuel pumps for the truck, one is 520 bucks under the injector pump title and the other is 275 under the title of fuel pump, so which is the one that fails?
Only lasted for a second tops but damn near stalled out in the middle of a busy highway....damn thing.
Jason
Old 11-02-2012, 06:29 AM
War is the answer!
What does it do under wot? Mine was the fuel water seperator. But mine would take off great from a red light but after that it was like a dog. Have you tested your pump to see if its bad or are you just guessing? Any CEL s?
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 11-02-2012, 08:18 AM
Just a guess since it happened on my way to work, will pull the codes from my cts to see when I get home. Under wot it runs fine, plenty of power and pulls my work trailer fine.
Jason
Old 11-02-2012, 08:41 AM
Well my CTS has decided to be a pos and I can't access anything on it, its stuck at my current display...
Jason
