IPR coolant filter and problems
I just noticed. I meant to put this in general not performance. Could mods change it? 2005 6.0 - DONE
I put my IPR high flow coolant filter and a new thermostat in four days ago. I was going to put the blue spring in at the same time but couldn't find the set of torx bits that has the right bit in it.
My truck always ran at 193*. A couple of months ago it started dropping to 182*-186* so I figured time for a new thermostat. I put in the new thermostat and moved over to install the IPR filter. I ran the in line from the black heater pipe to the in line on the filter and the out to the heater valve. I wanted it in line and very seldom need max/ac here in Maine in the summer. I finished and left in the warm garage for the night. The next morning I checked the coolant level, just below the minimum mark, and took it out side to warm up. I looked for leaks then let it warm up for a while. When I checked a little later the ECT was at 190* and the EOT was at 188* by the CTS. Happy with the new thermostat. I put the heat on max and waited for heat. The temp valve had been at max heat all the time it had been running so I thought I would get heat quick, but none came just very cold air. I figured must have air in the system so I took it to 3500 rpm and in a minute or so lots of heat. I left it running for a while and checked it again and it was ice cold in the cab. I noticed some anti-freeze on the black pipe and by the battery. I waited for my wife to get home in the evening so someone could run the throttle while I watched for leaks. By the time she got home it was about 45* I had her start it and I noticed the fan was turning and the AC lines at the condenser were getting cold. We went in and let it warm up. When we came out water was dripping pretty fast by the back of the inner fender. It turned out to be coming from the AC that was putting out cold like crazy. I had my wife rev it to 3500 and hold it their. I had used the factory clamp on the black pipe and it blew water from between the black pipe and hose clear out over the grill. I replaced the clamp with a screw type clamp, but that hose should have never built that much pressure unless it was dead headed somewhere. I checked the heater valve and it was open. I turned on max/AC and it closed. I thought although I didn't see any thing to bother maybe the hose had a kink just enough to cause it, so I ran a new hose with a big loop to be sure no kinks. Still the same. Now I figured maybe the heater core plugged although it would drive you out of the cab with heat before I started this endeavor. I spent hours back-flushing the heater with hot water, blowing it out, then cascade, then hot water, blowing it out, cascade again, hot water again, then I blew it out again and ran some distilled water through it. Water was crystal clear and ran right through. No luck still AC air coming out of the heater and the AC runs in every position except when the control is in the off position. I also noticed when I put it in the off position the heater valve closes, I didn't notice it do this before. I unplugged the vacuum line and the valve opened, so I left it unplugged so it would stay open, plugged the vacuum-line and tried again, still no heat. For some reason the water to the heater isn't circulating, I can hold my hand on the filter and it is just warm. The first time I started the truck and revved it up after getting up to temp I couldn't even start to hold my hand on it. Yes I checked the filter several times to be sure it wasn't plugged.
Fan running all the time AC putting out nice cold air all the time except when in outside air position and pressure enough to blow coolant clear out over the grill when revved up. Worked perfect the day before.. Maybe I messed up some wire when I mounted the filter. Hard to believe I could have though since I was doing my best to make sure I didn't, but it is possible I'm sure. My next moves planned are "first" to try it with the valve removed and "second" put the original hose back in to see what happens. I still can't figure why the fan is running all the time and why the AC works in all the heat positions.
I will be plowing my long driveway before long and I sure would like some heat. I just turned 92,000 and it has always been a trouble free truck. Just can't figure how my putting a coolant filter, that I very much like the design of, could start all this crap going on. I'm not blaming the filter itself by the way.
