suspension
2005 F250 CC has leveling kit in front and sits to high (higher than the Back even empty) what recomendations if any do ya got
Does the rear have any type of level? Blocks, add a lead, etc. if not then you'll probably need something to space it. What it the difference in height from the ground to the middle of the wheel wells?
It sits a 1 1/4" low in the back, No blocks, I got Bags on it should it be ok to have them at @45 PSI all the time to level truck without causing damage to anything truck,bags ect.
anyone ???????
I put a Rancho 2 1/2" coil spring level kit on my 05 F-350 and it sat higher in front like yours. I run around 25 psi in my bags to keep it level. 45 psi shouldn't hurt anything.
Thanks for the help i was hoping i wasn't the only one out there with this issue
I was thinking about getting new springs for the rear or just go with a add a leafs. But I'm worried about the ride comfort. I adjust the bag psi when empty for comfort on the highway.
Get some F350 rear blocks...
