Lift and tires question... - Ford Powerstroke Diesel Forum
Old 10-31-2012, 04:07 PM
Hey guys about to buy a 06 350 KR 4door 8ft well im wondering with a rough country 2inch spacer leveling kit can i fir 35x12.50/20 or 18inch tires under this beast? i love 35's but i dont want a 4in lift anyone got pics of their trucks with a 4in lift and 35's or level with 35's?
Old 10-31-2012, 04:30 PM
My truck has a 4 inch lift and 35 inch toyo open country mt. I think it looks perfect.
Lift and tires question...-photo.jpg   Lift and tires question...-photo-5-.jpg
Old 10-31-2012, 05:53 PM
You can fit 35/12.50's under a leveled truck, just have to get the backspacing right, the coil front ends don't rub or not as much as the leaf fronts do, can't remember which.
Old 11-01-2012, 08:18 AM
I bought some cheap eBay 2.5 or 3" spacers for the font. And blocks to matcht for the rear, clears 35's fine. With stock back spacing, and a tire upward of 11.5" wide, you'll rub the radius arms just a little, but aftermarket back spacing is fine with a couple inches of lift. I did also kinda fold back the inner fender liner in the back.of the front wheelwells, just under the front door hinge area, folded it back a hair, and tied it off with zip ties, looks clean, factory like from the outside.
Old 11-01-2012, 08:19 AM
I'm also curious, by logic you'd think that if stock to 2" of lift will clear a 35, you'd think 4-4.5" would clear 37's, but i think it might take more than that, like 5-5.5" to clear without rubbing. Any thoughts on this...not to derail your thread here.
Old 11-01-2012, 04:33 PM
The answer typically lies in the backspacing of the wheel. You can clear 37s on OEM wheels (though technically most 37s are too wide for oem wheels - another story) with just a 2.5" leveling kit. Change the wheels to ones that stick further out than the OEM ones and then you need more lift to clear the tires....
Old 11-01-2012, 06:06 PM
4.5" lift with 295/65/20's (35.5/11.50/20). I think they go together well.
