No power after EGR delete
Finished EGR delete turbo cleaning etc, got truck back started but have no power at all. I drove it around im thinking something is wrong with turbo, I also noticed some smoke coming from turbo. The only thing I notice is there is a thing behind battery on passenger side that seems to be missing a airline or vacum line, Im sure i left it off or pulled it loose during the process.
Thanks |
Possibly the turbo, but saying that u have smoke coming from the turbo- are you sure its not coming from the up-pipes or down pipe joints? There should be a write-up on this problem and to fix directions. I believe ur problem is that u have a leak in one of the joints.. When you installed the turbo did you leave it loose on the pedestal while attaching the downpipe and up-pipes? If not chances are thats why u dont have power(not building any boost). I had the same problem when i first installed my turbo.
I dont hear no leaks or any thing, the joints seemed to be flush when i put the clamps on them. I loosened both sides of the Y pipes at thr manifolds, I double checked sensors and wires and dont think I left any unhooked, but no power at all when I get to about 2000 rpm.
Whats your boost gauge read? I would guess a boost or exhaust leak.
Sent from my SCH-I535 using AutoGuide.Com Free App |
Dont think I have a boost guage
Codes? No monitoring solution? If not you need one. Check all clamps and hoses. Monitoring solution? If not you need one.
Sent from my SPH-L710 |
no codes, have the scanguageII, noticed there is a ziptie between intake and gasket that I will have to remove. Could that cause the problem.
hmm not sure what that is.. can u take a picture?
Do you have any tunes on the truck? Step out of the truck after koeo and listen to your fuel pump to see if it sounds weird. That's what my nonpower issue was. Mine was bad. If it was your turbo you would get a turbo code.
