Another smoke question - Ford Powerstroke Diesel Forum
Old 10-29-2012, 02:37 PM
I had just had my head gaskets redone with ford oem gaskets. My injectors were sent out to warrens to get reworked, new shims, washers and o-rings. I picked the truck up and noticed it still smokes a good bit when cold. Is that typical for bigger injectors? The truck is studded and deleted as well. I have an cts and all my essential readings are all good including ficm. What could still be causing the smoke? It's a greyish color. Thanks
Old 10-29-2012, 06:18 PM
Anyone have any suggestions?
Old 10-30-2012, 06:33 AM
Feedback Score: 3 reviews
Possible that the seals in the turbo leaking oil. You can disconnect the down pipe and look for oil.
If your running a custom tune, it's normal for gray smoke at start up. Some tune writers allow for extra fuel when first started.
Old 10-30-2012, 08:29 AM
Ahhh Hell Butch!!!!
Would this extra smoke for start also go for the Atlas 40 tune on the FICM? I noticed mine has been doing it since I got my FICM back as well. I don't run a tune program other than the atlas 40.
On that note, I notice today ( as I don't drive my truck often) I went to lunch from work backed up as I passed a empty spot, goosed it a bit and I got a puff of the bluish color smoke. Wonder if my it is time to check the turbo seals.
Sorry for the hi-jack!
Old 10-30-2012, 08:49 AM
More than likely just a little unburnt fuel in the cylinder.
Old 10-30-2012, 09:05 AM
Ahhh Hell Butch!!!!
Chief, you talking the intial start up?
Old 10-30-2012, 11:54 AM
NOT a Democrat
Dont forget it is a diesel. Mine does it when tuned and cold. Traits of my tune.
Old 10-30-2012, 01:32 PM
Ahhh Hell Butch!!!!
Even greyish white? Mine does it sometimes when warm and sometimes not. I am not as familiar with diesel vehicles as I am boat engines. You would think they are the same, but when you keep the engines on a bout on hot starts at 180 degrees only smoke your gonna gets is black and most of the time your in the boat and don't see. I just know I have delt with all the issues of the 6.0 yet and don't need to this thing to blow out on me next year when I transfer out of here. And being I never notice any this up until I upgraded my FICM, just kinda worried me.
