Natural Gas Conversion!!!!! - Ford Powerstroke Diesel Forum
Old 10-18-2012, 02:05 PM
Ok guys, I started a small company this summer, were currently working on a market for these natural gas conversion kits. As of now we are installing a kit on a 99 dodge 5.9 cummins. Father-in-laws truck, let him be the guinne pig! Anyways I'm going to do a small write up on the install and results. I've got a pending 05 f350 6.0 for a kit and also might put one on my 97 7.3.
I am located in Des Moines and we had our first natural gas pump put in this summer. The gas is at 1.99 per equivelant gallon, which is 5.66 lbs of natural gas I believe, the kit runs on 30% diesel the rest gas. It is supposed to provide 25% hp increase! the kit is self regulating flow by rpms.
The tank we have is about the size of a tool box in the bed, the regulator is mounted under the hood and simply plums into the air intake.
At this point we do not have mileage numbers, as I said I'm going to do a write up of the install on the cummins and post results later!! More to come!!!
Old 10-18-2012, 02:19 PM
War is the answer!
Ok
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 10-18-2012, 02:21 PM
last I read these were like 10 grand and the whole top of the motor was replaced for a 6.0?
Old 10-18-2012, 02:28 PM
The kits for the diesels simply plum the gas to be asperated through the intake. Our kit is complete and we've spent about $1500 on it, mostly due to the upgraded larger tank.
CNG for gas engines require full intake replacements and an expensive kit. If I recall correctly CNG doesnt burn hot enough to be a full conversion on a diesel engine. that's why the kit still uses 30% diesel fuel.
Old 10-18-2012, 02:58 PM
subscribed... awaiting results!!
Old 10-18-2012, 03:01 PM
Originally Posted by Stoker0560 View Post
The kits for the diesels simply plum the gas to be asperated through the intake. I have been wanting to do this for a while. Our kit is complete and we've spent about $1500 on it, mostly due to the upgraded larger tank.
I have alwayse liked the benefits of doing a light gas atomization. I orriginaly wanted to do a CNG but that will be way to much $$$.
Old 10-18-2012, 03:08 PM
How about LPG, wouldn't that be easier to fuel up with?
Old 10-18-2012, 03:18 PM
cng is the way to go and if you can keep price down for a coversion below $5000 that will work, sir you will be a rich man!
Old 10-18-2012, 03:19 PM
LPG isn't much cheaper than diesel, CNG IS $1.99 a gallon (equivelant) LPG has a higher btu but not much. If your ever near grimes the CNG pump is located just off I80 on hwy141. The fill nozzle resembles a hydraulic fitting if you will. Press on full nozzle and turn 180• to lock. The station provide a quick fill, although the pumps are rare locally, I foresee them popping up all over!
Old 10-18-2012, 03:21 PM
I'm telling you I have a diesel kit... Complete in my garage that cost a little over $1500 bucks. (granted it works as advertised)
