just bought 2007 need advice. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-18-2012, 10:37 AM Thread Starter
10secondC's Avatar
I just picked up a 2007 F-350. The truck has been given a clean bill of health by the dealer. I plan on doing the blue spring upgrade to the pressure regulator and I think I want to do the EGR delete. We have no inspection beyond a safety here on 2007 back over 8k gvwr so it would eliminate a big worry in my mind. Aside from basic monitoring which I already planned is there anything else I should do to make sure it's reliable? I do about 25k miles a year and 10-15 of that is with a trailer on.
10secondC is offline
post #2 of 5 Old 10-18-2012, 11:07 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
5w40 synthetic oil with Motorcraft/Racor/Fram filters. (all made by Racor) Meticulous coolant maint. and switching to a Cat EC-1 rated ELC coolant. The oil coolers clog and cause other downstream damage like head gaskets. An IPR Gen2 EGR delete is the best out there and I would also install one of their full flow coolant filters.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #3 of 5 Old 10-18-2012, 11:13 AM
The NEW frams are not made by Racor... I would just stick with motorcraft/ racor. But this seems to be it.. Monitor everything and keep all your filters and fluids clean. Enjoy..
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #4 of 5 Old 10-20-2012, 01:55 PM Thread Starter
10secondC's Avatar
OK...so I am driving the truck on a dealer plate for the weekend. Take ownership Monday officially. So it starts and idles fine when it's cold,but has crap for power till it's warmed up. Been 40's out. I know I need to look at FICM voltage.....I don't have anything to monitor the truck yet unless a Diablosport Trinity will monitor the voltages? Also I've read 15/40 oil may cause this symptom. How true is that or would I be wasting $100? The dealer put in Mobile 1 but I don't know what weight.
post #5 of 5 Old 10-20-2012, 02:01 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I know my truck is sluggish till its warmed up, but then again so am I.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
