Dead batteries again!!!!!? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-17-2012, 09:20 PM Thread Starter
Ok so I've had battery problems for weeks now I was having problems with the batteries dying I my truck set overnight well come to find out the voltage regulator on the alternator was bad and somehow I made it back from Tennessee after this happened by jumpin it off and hitting the road.. Got home put a new alternator and batteries in... The truck ran great for about 2 days then started running-idling rough until warm so I knew I messed the ficm up so I took it off did the fix myself at work yesterday but I didn't unhook the batteries before I took it off and I put the fixed module back on 2 days later and the batteries were dead as crap? Could me not unhooking the batteries caused this? I jumped it off and it ran great.... Funny thing though my alternator was warm to the touch after sitting all day? Could the switch be bad? Idk I've tried everything
2004 f250 Harley Davidson edition, 18" monster xd's on 35" trail grapplers, 4" lift, straight 5" exhaust to 6" tip, edge juice with attitude programmer, coolant filter
Stamey711 is offline
post #2 of 5 Old 10-18-2012, 04:33 AM
Lots of folks have gotten bad alternators right out of the box from the parts stores. Where did you get the alternator?
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #3 of 5 Old 10-18-2012, 04:45 AM Thread Starter
O'reilieys.... But I've had it rebuilt since I bought it 3 weeks ago and the voltage regulator was sticking and some brushes were bad so by no means was it a "new" one like they said
post #4 of 5 Old 10-18-2012, 09:38 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
I went through 3 before I got a good one.
Sent from my SPH-L710 using AutoGuide.Com Free App
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #5 of 5 Old 10-18-2012, 12:37 PM
Quoted: 2 Post(s)
article in current trailer life recommends that a ground wire be run from alternator to engine ground. said a lack of one cause a lot of problems. They were rebuilding alts for the turtle expedition truck.
HankY is offline
