Anything to worry about from truck being on its side? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-17-2012, 06:39 AM Thread Starter
hey all,
just curious to know if there could be any potential problems motor-wise after the truck has been on its side? had an accident resulting in a very graceful roll onto the passenger side. it was on the side for about an hour. i drove the truck home and to the body shop, everything seemed fine. thoughts?
oh and im sure your all wondering. it was quoted $18000 parts and labor. thankfully its 100% mechanically fine. should be finished today.
thanks
motor-man is offline
post #2 of 11 Old 10-17-2012, 06:43 AM
FordGuy100's Avatar
How long was it running on its side?
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #3 of 11 Old 10-17-2012, 07:00 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
$18, 000? You could buy another truck for that.
It should be fine depending on how long it ran on its side. It could have been oil starved running like that.
Sent from my SPH-L710 using AutoGuide.Com Free App
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #4 of 11 Old 10-17-2012, 07:20 AM Thread Starter
yes however this truck is my pride and joy and i would never want a new truck. the motor was running on its side for about 5 seconds.
post #5 of 11 Old 10-17-2012, 07:28 AM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
If you drove it after the fact and everything sounds/ acts ine I would not worry about it
Check all your fluids... I mean ALL of them. Tranny, Engine, Power Steering, Ect.
But if you know nothing leaked while at the scene of the accident then it should be fine!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #6 of 11 Old 10-17-2012, 12:50 PM
F250SixOH's Avatar
Why the hell didn't they total it?
F250SixOH is offline
post #7 of 11 Old 10-17-2012, 02:11 PM Thread Starter
Ya i know ill need to top up some PS fluid. That's all i could see that leaked. I guess the ccv is on the opposite side valve cover so i guess no oil in the intake.
Its a real nice truck, worth alot. Like i said it was pure body damage. I guess they knew better to write of a mechanically perfect truck. Thank god
post #8 of 11 Old 10-17-2012, 03:08 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
You'll be ok.
WarChild is offline
post #9 of 11 Old 10-17-2012, 05:05 PM
Quoted: 2 Post(s)
Insurance co's aren't totaling like they used to, ever since cash for clunkers. My dad has an 05' F150 2wd crew cab lariat with a salvage title due to a theft but the truck hasn't given him any trouble, so we suspect it was a joyride or something. Anyway, he ran up on a tall curb and damaged the sub frame where the lower control arms bolt up, and pushed the rack and pinion steering assembly up and into the motor, busting the steering lines. He took it to a local body shop, filed the ins. claim, and they ended up doing $8,000 in repairs. They replaced the frame from the transmission crossmember to the front, and they used the 08'+ front frame which relocated the steering assembly to the front of the crossmember and higher up to avoid damage. This also included new lower control arms, balljoints, etc. Most of the charges were in labor since it required removing the cab, motor and transmission.
All on a truck with a salvage title, 7 years old, and 90k miles.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #10 of 11 Old 10-17-2012, 05:14 PM
6.0f250firstcar's Avatar
How did you do a graceful roll?
6.0f250firstcar is offline
