I tried to hear it, but couldn't hear anything.
It's there but hard to tell with the road noise. Best I can describe is like a cricket. More noticeable on second video when I am on/off the throttle.
Unusual noise, very hard to tell anything from that video. Unless someone has heard it before your probably on your own.
So, you are going to have to isolate it system by system, as it could be anything. It could be caused by anything from the a/c fan to something that is mounted loose inside the engine compartment or inside the door that only rattles at certain speeds and road surfaces. You need to consider everything and then start eliminating variables. Maybe a mechanics stethoscope could help you isolate the loudest area and you can dial it down from there. Just be the passenger, not the driver while doing that... |
Could be a cracked y pipe
It's definitly in the engine somewhere. AC was off so don't think it is that, fan clutch is working fine, deltas are close to each other. If it were a cracked y pipe wouldn't I see an increase in EGT's and hearit all the time? Was wondering if it could be a bearing of some sort?
I'm wondering if it has something to do with the tune or higher elevations. I'm home close to sea level, I changed my tune to ID Extreme Street and can't hear the noise now.
Since I've been home I have switched to ID Extreme Street and have only heard it twice but it was very faint and only lasted a second or two when only being started for a few minutes and I was getting on an on ramp. Turbo bearing seemed good with no play in blades while pulling on it with my hands. What kind of noises would I hear if my turbo was on its way out?
That's my guess too. It'll only get worse as time gos on.
Anybody have a video of what a cracked pipe sounds like?
