Turbo boost
Today or just about 20 minates ago I got into it n the boost went. To 26 never went pass 22 to 23 and it took off like a rocket is that close to normal only had the truck for a month now 93000 now oil cooler n filter on it
Yes thats normal, you vanes are probably sticking. Mine are, could only get 19 or so, kept gettin on it, got up to 24 over time. I could ful the difference.
Sent from my phone that somebody didn't help me get. |
Could also be bearing going bad.
Sent from my SPH-L710 using AutoGuide.Com Free App |
I'm a little confused by your post. So you're seeing higher boost then normal? How are you getting such an accurate boost reading? Are there any issues besides seeing higher boost numbers? Also, what year truck are we talking here?
Because 26 psi of boost isn't that bad. If you were seeing over 30 psi then I would say you have an issue. If you had sticking turbo vanes or any other air management issues then you should have other driveability issues such as low power taking off. It could also be a few other things such as a biased/mis-reading EBP sensor. |
Me too....
Your post was kinda confusing. I thought you were seeing only like 22psi. I see 32 psi sock with my tunes and my veins are not sticking. My brother in laws turbo was running up to 28psi and started to run 22-23 max and took it out and found the bearings were bad. Went with a powerror max. You should see 28psi sock.
i have never seen 28 , i did try a few more times but 23 was the best ,thruck runs real good,think i just need to stop worry about it and enjoy it.maybe wax it today
