egr question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-10-2012, 06:43 PM Thread Starter
egr question
Can I remove the egr throttle valve on my 04 excursion while im doing the egr delete?
Thanks for the help
04 Excursion 4in lift
SCT X3 econ tune
Edge insight
Blue spring mod
4in MBRP SS no cat
Adrenaline Hpop
ARP's
Ficm repair with Atlas 40
CCV mod
BPD delete and water pump
need high idle mod soon
Pioneer DD head and 1k amp pushing two 12's and it was good.
averageguy is offline
post #2 of 3 Old 10-10-2012, 07:00 PM
Term3's Avatar
I just removed the disk itself and left everything else the way it was. There always seems to be issues with unplugging things in the EGR system depending on flash version I just didn't want to toss it in the trash then find out months later that it effects something else and I need it plugged in again.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 3 Old 10-10-2012, 09:45 PM
scha0786's Avatar
Quoted: 19 Post(s)
leave the egr valve plugged into the computer. If you can leave it in the manifold or just lay it up top on the engine.
yes you can remove the butterfly valve too, leave all those sensors plugged in though
04' F-250 6.0L
AFE Stage 2 intake
Liberator EGR delete kit
4" MBRP Turbo back (straight piped) WHISTLE
Quad Piller Gauge
zoodad mod
Nitto Dura Grapplers
Edge Insight CS
DieselSite Coolant Filtration
Upgraded fuel pressure spring kit
upgraded turbo oil supply tube(solid)
upgraded turbo drain tube
SWAMP's 48V FICM
Rotella ELC
Firestone Ride Rite air bags in rear
draw-tite 30k hide-a-goose kit
scha0786 is offline
