constant door chime
as of this morning i have a constant door chime when the truck is off and the driver door is open. put the key back in and turn to run position and its gone, close the door and its gone and while driving/running is gone. what is this? is there a fix or a way to disconnect it all together? its only been a day and its driving me nuts
There is a pin sticking in the ignition tumbler. You can try dry graphite lube to release it.. If that doesnt work you may have to replace the ignition switch (it worked on mine)!!!
i just rebuilt the ignition with ford parts not more than 8 months ago. worth a try i guess
Well that seamed to do the trick. Thanks
and now its back. guess im going to try and take the ignition out and reassemble it.
and fixed. pulled ignition switch out, and took off the black wire with pink stripe from where it connects to the ignition switch. electrical taped in case i need it again and done. so much quieter now when i get out
That's what I did. LOL I wrote a writeup on here about it like 4 months ago.
