New noise developed - Ford Powerstroke Diesel Forum
Old 10-08-2012, 02:58 PM
New noise developed
I recently noticed a noise that my truck makes while under light acceleration. The best way to describe it is a low pitched flute type noise, not really a whistle. It's hard to hear unless you are listening for it on purpose. It happens above 2K RPM but goes away under WOT accel. I know that my drivers side up pipe leaks at the flex joint so I'm thinking that is probably where its coming from. If it were a head gasket, I've heard the noise is loud, more of a higher pitch, and more whistle. Probably would lose coolant as well right?
Old 10-08-2012, 05:37 PM
I hear a high pitch noise similar to what you are talking about but it only happens when i press on the skinny slighty just taking off for an example.. This sound appeared when I installed an airraid intake... Probably the culprit.. If you had head gaskets issue yes you would lose coolant
Old 10-08-2012, 05:48 PM
Oh okay, no coolant loss at all. Guess Ill be checking all the intake and CAC tubes for leaks as well.
Old 10-08-2012, 06:33 PM
If you had cac tube leaks you would know it. The truck would be very slow to respond and produce no boost. I am familiar with this noise your describing and it sounds normal with the 6.0 turbo... I hope im right in guessing your sound. Going out on a limb.
Old 10-08-2012, 09:03 PM
Cac boots split/cracked, exhaust flex joint cracked. Both are not uncommon.
Sent from my phone that somebody didn't help me get.
Old 10-09-2012, 01:10 PM
Thanks for the help.
