No brakes - Ford Powerstroke Diesel Forum
Old 10-06-2012, 03:59 PM
No brakes
Today while driving I would push down on the brake pedal have brakes for a second then the pedal would hit the floor. Eventually the pedal would go all the way to the floor and I would have to push as hard as i could to get the truck to coast to a stop. The brakes would also take a second to disengage and the pedal was slow to come up. All levels are good with no leaks. Can anyone point me in a direction of what may be wrong with the truck
Old 10-06-2012, 07:04 PM
War is the answer!
Break booster might be bad.
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 10-07-2012, 03:08 AM
You could have a pin hole in one of the brake lines.
Old 10-07-2012, 05:29 AM
My vote is also on the brake booster. You noted that your fluid levels are good and steady so that would, to me, eliminate a leak in a line or at the calipers.
Old 10-07-2012, 06:24 AM
War is the answer!
If he had whole anywhere in the system he would be losing fluid.
Old 10-07-2012, 07:20 AM
How do I tell if the hydroboost or the master cylinder is shot.
Old 10-07-2012, 07:39 AM
Ok I found a small leak under the brake pedal
