99-06 to 08+ Mirror Conversion using uplifter switches?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-06-2012, 05:56 AM Thread Starter
mlux2008's Avatar
I had a thought that would possibly allow me to keep a seemless install.
My current truck is an 06 F350 lariat. Has stock power mirrors with turn indicator, heat, manual telescope.
I would like to convert those mirrors to the 08+ mirrors but I don't want to cut up my bezels and install corny switches. I would like to leave everything looking factory, but I want the power fold and power telescope. So my thought is possibly using the uplifter switch. Using one switch to telescope and another to fold. Has anyone tried this? or know of any way to make this work? any thoughts/advice would be appreciated.
Thanks
Matt
2006 F350 Crew Cab Long Bed 4x4 DRW Lariat 6.0
EGR Valve delete
Arp Head Studs w/ OEM head gaskets
SCT tune
Upgraded Coolant filter
Upgraded Oil Cooler
Edge Insight w/ Probe kit and Turbo timer
2008+ Super Duty tailgate
20% tint all the way around
Possibly looking into:
exhaust
Upgrading audio and security
mlux2008 is offline
post #2 of 5 Old 10-06-2012, 06:40 AM
DieselV8's Avatar
I would think you would need a three way switch for that, as the upfitter switches are just on/off.
06 F250 Crew Cab, Lariat-FX4, ScanGauge II, High idle mod, Heated mirror switch mod, Sinister bypass oil filter and coolant filter, Fumoto valve, Zoodad, Blue Spring
DieselV8 is offline
post #3 of 5 Old 10-06-2012, 06:43 AM Thread Starter
mlux2008's Avatar
Thats what i thought too. But I have also considered using all 4 switches. Granted it isn't the BEST use for all 4 of them, but I don't have any other use for them.
I could set it so that when you flip one on it folds in, flip another switch to fold out. Another switch to telescope in and another to telescope out. Unless they have a 3 way uplifter switch that you can change and still look factory. Or somehow convert it.
Matt
EGR Valve delete
SCT tune
Upgraded Oil Cooler
exhaust
mlux2008 is offline
post #4 of 5 Old 10-06-2012, 07:11 AM
Term3's Avatar
I'd look around for a three-way that looked similar to factory or even replace all four so they all look exactly the same. A three-way is just so much easier to use instead of hitting one side of a normal switch then when the mirror is in the correct position move your finger the other side of the switch to power it off. I just have visions of say the switch for the power extend accidentally being turned on and no one noticing for a long time which would probably burn out the mirror motors or screw up the gears in those expensive mirrors.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 5 Old 10-06-2012, 07:19 AM Thread Starter
mlux2008's Avatar
Completely agree. what are the odds that I would find a switch that looks factory and is a 3 way. Been looking all over the internet and no luck Thanks for the advice.. If i can't find anything I'll probably try to get creative with what ford did on the 08 cluster on the driver side
Matt
EGR Valve delete
SCT tune
Upgraded Oil Cooler
exhaust
mlux2008 is offline
