Puking at higher elevations - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-05-2012, 11:06 AM Thread Starter
Adamv7010's Avatar
Driving in the Mtns today when I stoped for fuel I took a look under the hood and its been puking some.
When I left home I had no known egr issues. Hg and deltas are both good.
Coolant level when cold is right at the old minimum mark..
Elevation is around 6500ft
Most boost I've seen is 16psi w deltas 16* at highest.
Highest ect was 203
I'm using an insight.
Think my bottles just a little overfilled....or will the higher elevation play into factor?
Sent from my Motorola Electrify using AutoGuide.Com Free App
Adamv7010 is offline
post #2 of 8 Old 10-05-2012, 12:08 PM
ICBM99's Avatar
Elevation does play into things. The boiling point of water at 6500 ft is about 199* F. Barometric pressure also makes a bit of difference.
That's the reason there are different cooking procedures depending on elevation.
Linky: Boiling Points of Water at Various Elevations
ICBM99 is offline
post #3 of 8 Old 10-05-2012, 12:10 PM Thread Starter
Adamv7010's Avatar
I was thinking so. It hasn't puked again at all yet so we'll see. And I've been in a few high boost climbs again. I'm thinking it's overfilled a little
Also the barometric pressure was around 17psi
post #4 of 8 Old 10-06-2012, 11:05 AM
I was in the same situation yesterday. I went up to an elevation of about 10,500 and this morning saw some puking. I got real nervous but am glad to see these responses. No known EGR issues and my max deltas were 11 degrees.
2007 F350 6.0L FX4 Lariat CCLB
MBRP 4" w/ 5" Tip turbo back, no cat
Toyo MT's 315/60/R20
Edge Insight CS w/EGT probe
SnugTop Super Sport
sanctified is offline
post #5 of 8 Old 10-06-2012, 12:10 PM Thread Starter
Adamv7010's Avatar
My deltas got a little higher than you...but I ran that baby harddd in tow haul. I'm on stock bolts...and of it was to break I wanted it to do so
But I dont want it too ha
post #6 of 8 Old 10-06-2012, 06:02 PM
I was taking it pretty easy and was going slow. The fact that it was only 34 degrees when I was climbing helped I'm sure. I am also stock and don't have too much much info or history on the truck since I bought it just a couple weeks ago. I also wasn't towing anything.
SnugTop Super Sport
post #7 of 8 Old 10-06-2012, 06:08 PM Thread Starter
Adamv7010's Avatar
I wasbt towing...but I was pushing her hard up those little hills
But aside of that little puking she did great...I feel alot better now that someone reinforced my opinion on what was going on w it
post #8 of 8 Old 10-06-2012, 06:58 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
I have my truck going up the sierra mountains twice a month and everytime the water climbs in the coolant tank.
First time I saw it, yea my eyes got real big but it does it every time I go. Like I said open up the cap slow and you will watch the coolant level drop to the same level you are used to seeing in the valley or where ever you normally live.
My truck has no issues eot/ect is 3-5 degrees healthy as a horse, but climbing 5000 feet makes a difference, atmospheric pressure is lower. 10,000 feet is a hell of a change. Lower your coolant level and it won't blow out, there is less atmospheric pressure: (your water is getting bigger w/lack of pressure to make it as easy for me to explain)
Again you are fine! Mark...............
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
