Tools needed to drop fuel tank question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-05-2012, 07:02 AM Thread Starter
Quoted: 2 Post(s)
Are there any special tools required to drop the fuel tank on my 2004 F250 6.0?
Once upon a time I had a gas F250 and I needed a special tool to disconnect fuel lines. Using the thing was a real PITA.
anthropisces is offline
post #2 of 3 Old 10-05-2012, 07:17 AM
juzatheman's Avatar
Im not 100% sure but if it have connectors like my -03 excursion then no need special tools only small screwdriver. To disconnect lines.
juzatheman is offline
post #3 of 3 Old 10-05-2012, 10:52 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
You could just lift the bed so that you don't have to undo the fuel lines, all you need is a Torx socket and either some help lifting it off, or a floor jack and a piece of wood to jack it up enough to work on the tank.
Like this:
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
