im changing my 6.4 banjo bolts back to stock bolts - Ford Powerstroke Diesel Forum
Old 10-04-2012, 04:36 PM
The more i have researched and read how the fuel system works im gonna put my check valve stock bolts in, the fuel system is designed to keep pressure in fuel rail and 6.4l banjo bolts dont have check valve so everytime you shut off the motor the fuel leaves the fuel rails there fore i belieave would lead to extend cranking times.
Old 10-04-2012, 05:06 PM
when you turn the key on, the relay comes to life and the system primes itself,,,,,, now that may take longer, but cranking should be same. not to say it is, but should be. i have heard of no complaints about extended cranking, just reports of NO GAINS, after switching
Old 10-04-2012, 05:12 PM
ok u got me talked into leaving if alone, even though i never use glow plugs haha, and turn they key like a gas motor, i only use gp first intail start of the day
Old 10-04-2012, 05:32 PM
Actually, the stock 6.0 banjos have check valves in them to try to prevent what is called helmholtz resonance. Shockwaves in the fuel rails, to put it simply. The 6.0 is a dead ended system, the 6.4 is not, hence no check valves in the 6.4 banjos.
Sent from my phone that somebody didn't help me get.
Old 10-04-2012, 10:15 PM
Holy Fawkk! I did this once, idk what i was thinking, but she didnt start. It freaked me out but then remembered. tryied it again, waited for teh light to go off and it started w no problem. So urs starts up fine every time ?
Old 10-05-2012, 02:52 AM
Been running 6.4L banjos for a long time with no issues. I can't see how the fuel would drain out the rails. The system maintains fuel pressure static when shut off. Perhaps the FP regulator spring is weak allowing the return side to open. This would allow the rail pressure to bleed off over night.
Old 10-05-2012, 04:39 AM
Thanks for the knowledge.. i do use my gp everymorning for the first start up of the day but that's it and yea it starts up fine, but my batterys are starting to get weak and im not turning over the motor fast enough so i do have a littlle bit extend cranking right now. i have started it with out gp in pretty cold temps and still starts fine, but i live in florida so pretty cold is 40 degrees..
Old 10-05-2012, 04:42 AM
and i have put 6.4 banjo bolts in over 50 trucks around here, i was just doing research on fuel system and i knew it was a dead head system so i figured well the check valve might be useful.
Old 10-05-2012, 04:59 AM
i use the GP light when its on, otherwise i wait for the fuel light and water in fuel light to go off. starts great. what i have noticed, is on cooler mornings, mid to low 30's, is if i plug in, the truck starts rougher than using the GP. i guess some heat doent allow GP time to fully heat combustion area as well.
Old 10-05-2012, 05:17 AM
War is the answer!
The bank bolts don't make any difference what so ever. Ether way you go there is nothing worry about.
Sent from my SGSIII running a custom ROM.
