37 inch tires? - Ford Powerstroke Diesel Forum
Old 10-21-2007, 06:45 AM
37 inch tires?
I'm new to the site and thus far haven't been able to find an answer for what i'm wondering. I want to know if you can run 37x13.5x20 or 22 on an 06 F350 with only a 4 inch lift. I would go with 35's, however I really want the Kumho Road Venture MT KL71 tires but I can only find 37 inch sizes and I don't want a lift any bigger than 4 inch due to being a daily driver for my company. So if anybody can help point in the the right directions it would be very much appreciated.
Old 10-21-2007, 06:47 AM
International Threat
Cut out flares maybe.
It also might depend upon the backspacing and how much of a turning radius you want to give up.
Old 10-21-2007, 06:53 AM
IU Hoosier Fan
I think about anyway you would try to work that it would rub no matter what... I have a 8' lift and I still rub a little with 37's but that is only when I turn it as hard as I can...
Rob Rob is offline
i dont think you are gonna be able to fit 37's on a 4'' lifted truck. i have a 6'' with 37x13/50x18 Toyo M/T's and come real close to rubbing, i also do rub a little bit on the leafs, but that is because i dont have an offset rim.
Old 10-21-2007, 07:29 AM
You aren't from the Dallas\Ft.Worth area by any chance?? Forget I asked. Welcome to the forum by the way.
Old 10-21-2007, 08:47 AM
You can as long as you don't need to turn. I have a 6" and 37's rub more than I like.
Old 10-21-2007, 09:21 AM
+1 more for its gonna rub.... im running 37" tires on an 8" lift and still rub at full turn... i know its diff because we run leafs up front but with a 4" lift youll have to do some cut out fenders like marty suggested and some off-set wheels to make them fit and you might still rub
-Raul
Old 10-21-2007, 09:25 AM
Yeah, forgot about that. I rub on the fenders with a 6" lift and I have offset rims.
Old 10-21-2007, 10:01 AM
6" of lift and 37X12.50's here and no rubbing but VERY close when I turn and have the truck flexed up a bit. Close enough that I will be trimming the bumber here before too long. I say 37's and 4" of lift probably will not work.
-Aaron
Old 10-21-2007, 11:57 AM
Yah I pretty much figured that would be the case, I was just hoping it could maybe just maybe happen so I could run those tires. I'll probably just end up going with a 2 to 3 inch lift with 35's on 20's.
Thanks for the imput tho guys, I'm sure I'll have more questions to come as I'm just new with the power stroke. I actually don't even have my truck yet, hopefully sometime this week, but of course I've gotta start planning everything.
