SCT - Ford Powerstroke Diesel Forum
Old 10-20-2007, 11:49 PM
SCT
Well after hearing everybody talk about the SCT i have decided to go with the livewire, can anybody tell me where the best place to buy it and to get the best tunes for it, and i am also going to do a zoodad to my truck when i get home also. Thanks for all the info guys
Old 10-20-2007, 11:54 PM
you might try Pat or Larry at discount power parts
Old 10-21-2007, 12:14 AM
Thanks i will check them out.
Old 10-21-2007, 12:56 AM
matt at spartan diesel tech is one sick tuner for the SCT. the guy really knows how to wake these trucks up !! call him or evan. efoster is on here and writes some killer tunes !
Old 10-21-2007, 04:13 AM
LTJDS
Talking Innovative, through DiscPowerParts.
You might try Pat or Larry at discount power parts
I Agree
They use several people and are very Honest and Up front with ya'
I bought my LiveWire from them and got tunes from "Eric @ Innovative Diesel"
Through Larrry @ DiscountPowerParts.com.
PS: I have been running the Extreme/Race from Innovative all DAY every DAY,
and since purchased I have not been beaten by anybody as of the 6-7 months I have had their Extreme/Race Tune Installed. Through Larry or Pat at DiscountPowerParts.com they get Innovative to custom tune your SCT.
The X-cal or the LiveWire both come from SCT with a MAX Hp tune of 120 HP
, While the Custom Tune from "Eric @ Innovative" is an additional 160HP based on custom tuning for your truck and the mods you have already made.
DPP, Larry or Pat can tell you the other tunes available from the Guys at Innovative, I know they also have an economy, a Tow, and a Extreme/Street.
The Main thing I like the most about Innovatives Tunes is that when you use the Rule" 100*F on your Pyro per 10MPH" they are either just under or "Spot ON" . Ex. I run at about 80 MPH on the freeway on commute to work and my 6.0L usually will run , while at 80mph , between 700*F to 800*F , which is usally colder than normal standards. When running the considerable amount of mileage my commute requires to and from work (120) each way. Having a Bad Arse Tune, that can run and it's colder than other tuners ,Tune's. Other Tuner's set up their Hottest (Baddest) Tunes as if they are set up for 1/4 mile
runs ONLY. I have found Innovatives "Extreme/Race 160hp" is good and safe for All Around driving conditions except , maybe towing more than 1500lbs.
Either way make sure you have a properly located and installed EGT/Pyrometer and a Good Independent Tranny Temp Gauge, and you should be fine.....
Old 10-21-2007, 04:32 AM
Thanks man i will check them out and probably go ahead and order it and have sitting at home for when i get there that was very helpfull info
Old 10-21-2007, 04:46 AM
u going to love it i have run many chips but the SCT is the winner by far
Matt
Old 10-21-2007, 06:27 PM
that 100 rule is kind of interesting, and i've noticed myself that it usually holds true, and the boost is usually on par also..
like when cruising down the hiway, i will usually see about 800* at 8psi, when i'm at 10psi i usually see 1000*
are you referring to "canned" tunes only when you say the XCALII good for a max of 120HP? because i know i'm making more than that. and Logan has put down 440HP at the dyno with an sct and a straight pipe
Old 10-21-2007, 07:52 PM
The Lady Mod
Send a message via Yahoo to Granny
I have run tunes from both Matt at Spartan and Eric at Innovative and both do great work. Matt is here in North Carolina.
Old 10-21-2007, 08:01 PM
hey granny i havent been on TDG lately, is my boy still backing down about going to NC to run me ?
