EGR delete?? - Ford Powerstroke Diesel Forum
Old 10-17-2007, 03:58 PM
EGR delete??
I have read about programmers that have egr delete. What exactly is that, can the programmer shut it down leaving no future worries? For the record, mine was just replaced under warranty.
Old 10-17-2007, 04:14 PM
ADMIN AND TECH
yes there are programmers that have the egr shut off option , but from my experience the possibility of egr problems is still there, in my opinion shutting the egr off manually only allows more heat to build up in egr cooler because the pcm is not able to allow it to open and release exhaust gasses into the intake , ive seen several with egr problems with this setup, , in my opinion doing the egr delete in the exhaust is the way to go , and have had good responses from customers with that done
Old 10-17-2007, 04:20 PM
Is it much of a job performing the delete in the exhaust?
Old 10-17-2007, 05:24 PM
no its easy..hardest part is gettin the inner fender liner off.....
Old 10-17-2007, 05:25 PM
can be if you've never done it before.
Old 10-17-2007, 05:26 PM
ADMIN AND TECH
the hardest part is getting the rusted bolts out
Old 10-17-2007, 05:53 PM
Slacker
Feedback Score: 4 reviews
Yeah, when Marc did mine, he cut my old up-pipe off... It's real easy with an 03 and 04 model because they don't have an inner scoop in the up-pipe like the 05-07's do. Pull off the passenger side tire, remove your exhaust down pipe, and loosen your up-pipe and slip the block off plate in the neck next to your EGR cooler and put her back together.
I say that like I've done it, but Marc's the man!!! He's probably still enjoying my Crown Royal...
Old 10-17-2007, 06:00 PM
Thanks guys. No rusted bolts here, I bought the truck in Florida and drove her north. She's spotless.
I wish I knew about this while I had the downpipe off when I installed my exhaust......Oh well. Looks like another thing to do this weekend. Oh yeah, does someone offer some sort of a block off plate?
Old 10-17-2007, 06:05 PM
Elite diesel........
Elite Diesel Engineering Engine Parts for your 6.0L Powerstroke
Old 10-17-2007, 06:46 PM
Slacker
I thought the exact same thing since my truck's only been in the sunny desert of AZ... Best of luck to ya! Your engine and mileage will thank you...
