Those with Airdog 2, I need some help!
571 views 1 reply 2 participants last post by  jimmyv13
Can someone look at their pump and verify the red lead coming out of the pump is the positive and the green is the negative? I decided to make a new wire harness running 10 AWG wire to the pump and when I took the harness side connector apart I found the black wire hadn't even been stripped before the terminal was put on and it had just barely poked through the insulation. Anyway, lost track of which was the positive and negative. Thanks!
