XDP EGR delete and oil cooler package
I am in the process of ordering parts. I am planning on installing an EGR delete with up pipe, and oil cooler, and any gaskets, etc.
I also need a y-pipe since mine is cracked. Has anyone used this package? XDP Powerstroke Solution (XDP EGR Delete Kit, Oil Cooler and Intake Gaskets) Any other suggestions are appreciated. |
This is the route I always go! Will save ya about $180!
Tousley Ford Parts Depot EGR Delete Kit | Ford EGR Delete Kits | 6.0 EGR Delete Kit |
I have the xdp kit and it does just fine no problems at all and they are SUPER to work with.
decisions decisions.....Are all of the EGR delete kits basically the same? I just want to make sure im putting a good kit in and something that will last. Is there a real difference in the Sinister kit ($300) and a $169 kit?
I have installed at least 10 of the Custom Diesel kits and the welding is perfect on them! If they would cut me a deal to buy 5 at a time I would buy them like that.
I am running it on my personal truck and have not had a minutes trouble! All the delete kits are basically the same. some have the welded coolant pipe, and some have like a fork that holds the coolant pipe down. I prefer the welded one if it is done right. And the Custome diesel has never disappointed! |
I just put this kit in, can't beat the price for $110, and the quality is good.
FORD 6.0 6.0L 2003-07 EGR DELETE KIT F250-F450 POWERSTROKE SUPERDUTY DIESEL | eBay |
As for the Y-pipe. I have the Maryland Diesel Y-pipes with the heavy duty mesh flex installed.
http://www.marylandperfdiesel.com/_e...D_Up_pipes.htm |
Thanks guys, You have all helped save me some money!
Do I need to install the updated STC fitting while im in there? Is there anything else that i need to do while i have this apart?
Bump.......
