Dtc - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-17-2007, 09:12 AM Thread Starter
pavnman's Avatar
Dtc
I have a code of PO401. Truck feels like it is running on seven cylinders please advise.thank you jake
pavnman is offline
post #2 of 4 Old 10-17-2007, 09:16 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Do you have a 6.0? I will move this to a different section so you will get more people to see this thread. This is the code P0401 Exhaust Gas Recirculation Flow Insuff Detected. That is your egr so Im assuming you have a 6.0
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 4 Old 10-17-2007, 09:22 AM Thread Starter
pavnman's Avatar
Dtc
yeah its a 6.0 04 250 it really runs like crap if I put it on stock setting it runs even worse
pavnman is offline
post #4 of 4 Old 10-17-2007, 09:28 AM
vitalidle's Avatar
Sounds like your egr might need to be cleaned, but Im not positive. I moved this thread to the 6.0 section so more people will see it to help out
Auto 93,000 miles
DP Tuner F5
