6.0 Starting problem - Ford Powerstroke Diesel Forum
Old 10-16-2007, 06:56 PM
I stopped tonight and my 6.0 wouldn't restart for about two hours. No error codes on my message center or check engine light. Any suggestions? Does this model have the CPS problems that the 7.3's have?
Old 10-16-2007, 07:54 PM
I don't know nuttin....
No CPS issues here. Wouldn't start "for" two hours or wouldn't start "after" two hours?
Oil level good? Fuel pressure good? Whats the temp. outside there?
Won't start at all even with a long crank - 30 seconds or so?
Old 10-16-2007, 08:19 PM
what year is it ? could be ICP issues ?
hpop tube or something is common on 05 i hear.
Old 10-17-2007, 05:13 AM
It isn't cold or anything. It wouldn't try to hit a lick until after it cooled off for a few hours. What the heck is an ICP?
Old 10-17-2007, 05:26 AM
Slacker
Feedback Score: 4 reviews
It's probably the High Pressure Oil Pump leak at the quick disconnect. I had mine replaced and it hasn't done it since. I spent about six months fighting with the dealership (it was a bad one) about the problem. I stopped shutting the engine down unless I knew I was going to be there a while... BTW, they now install a girdle on the HPOP to prevent it from recurring.
Old 10-17-2007, 05:31 AM
Thanks Evil Eye. THat'll at least give me somewhere to start with the dealership so I don't get jerked around too bad. My truck is my office, so I can't afford much downtime. Luckily I still have my 2000 7.3 with over 300K on it to use!
Thanks for all the info guys!
Old 10-18-2007, 09:14 AM
again, WHAT YEAR is it ? the ICP is injector control pressure, and the HPOP i mentioned is the high pressure oil pump.
Old 10-18-2007, 09:17 AM
He says its a 6.0 liter so what real difference does the year make here?
Old 10-18-2007, 09:25 AM
ADMIN AND TECH
Because
the '05 is WAY more common to have this issue then any other year.
Old 10-18-2007, 09:35 AM
Jon
Guest
Posts: n/a
'05
Yes it is an '05. Here Clay.
2005 6.0L Stalls
