05' SD Rear axle vacuum???
My rear vacuum line came off from the top and was hanging on the axle. I'm assuming somewhere by the frame rail, I got under there and couldn't find anywhere that it was hooked up. I'm hoping that someone will go under there truck and take a pic and post it for me. I really appreciate anyone's help on this situation, Thanks JT
Are you talking about the vent line?
Sent from my Autoguide iPad app |
Hey bud, that's not a vacuum line its a breather tube for the axle. It doesn't connect to anything other than the axle. It should have a plastic clip on the line near the end or the clip may still be on the frame near the spare tire.
Sent from my DROIDX using AutoGuide.Com Free App |
Yes, that's the one... Wow! No wonder I couldn't find the vac tube.
![]() michaelbyoung & strokin07 Thank y'all so much for the quick responses... |
Not a problem
![]() Sent from my DROIDX using AutoGuide.Com Free App |
No problem man
check to see if its plugged too, you don't want to end up with a pinion seal leak
