6.0 Squeaking and A/C ???? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-22-2012, 11:57 AM Thread Starter
Question 6.0 Squeaking and A/C ????
I recently acquired a 2003 Ford f250 Lariat CC 6.0, 2wd, 100th centennial.. The truck is great, so far ive got a 4" mbrb turbo back exhaust and thats it. Now I have a few concerns that maybe you guys can help me with. Truck has 170k Miles. When I start the truck and its cold theres a squeaking sound coming from the front of the engine by the belts...This completely goes away when the truck gets warm.
Next issue is with the A/C .. It only blows cold A/C sometimes maybe 50% of the time while driving from point A to point b. This has me stumped..
Any help will be appreciated.
Thanks
Mgonzo700 is offline
post #2 of 9 Old 08-22-2012, 02:39 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Squeak could be coming from either the idler/tension pulley bearings, dirty belt, or alternator bearings.
I don't know enough about A/C systems.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 9 Old 08-22-2012, 03:46 PM Thread Starter
Thanks..i will check this out.
post #4 of 9 Old 08-22-2012, 04:08 PM
Jonboywv12's Avatar
Send a message via AIM to Jonboywv12
same boat, i dont have the squeaky sounds, but a/c blows cold when truck first turns on and while driving but after it stays at a certian rpm for a while it blows what feels like the heat off the engine haha then you give it some more throttle and it chills back up again for another 20 min or so then its warm again...if the truck idles for more than 15-20 min it blows warm as well. any help would be great.
not trying to steal thread MGONZO700 just questions...
Jonathan or Jon
2002 F-350
4" Banks turbo back exhaust.w/5" tip
4" Banks down pipe
Banks Big Hoss turbo waste gate
6" SKY JACKER
35" Nitto All-Terrains
TW chip 6 pos.
Banks Trans-Command shift kit
AFE STAGE II Intake
Gauges (boost, EGT)
102" whip antenna (guaranteed 100hp!
enough for fun!
Jonboywv12 is offline
post #5 of 9 Old 08-22-2012, 04:12 PM Thread Starter
Yup same thing going on here
post #6 of 9 Old 08-22-2012, 04:23 PM
Jonboywv12's Avatar
well...damn. hopefully we can get some answers!
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
post #7 of 9 Old 08-22-2012, 06:04 PM
tpridgenusmc's Avatar
I was having the same issue with my A/C, well almost the same issue. The A/C would ALWAYS blow warm, not too much of an issue here in WA where I'm sationed, but on a warmer day here enough to make it uncomfortable. I recharged my system and it worked like a champ...For about 20 minutes or so. I did some research and found that the air gap on the compressor would get out of whack over time. A REALLY easy fix. After I did this it worked like a champ, and NEVER blows warm air!!! I love it. I got this fix from somewhere, either here or on the Nation. Hope it helps. SpringerPop's Compressor Clutch Air Gap.
Trey Pridgen
United States Marine Corps
'03 F-350 XLT 6.0L, CCLB, 4x4
tpridgenusmc is offline
post #8 of 9 Old 08-23-2012, 02:04 PM
Jonboywv12's Avatar
wow that doesnt seem to hard at all! im guna have to try that out! i dont think i even own one of those thickness guages is there something else i can use to compare that too?
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
post #9 of 9 Old 08-23-2012, 02:19 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
You can pickup a cheap 1" micrometer from sears for around $20.
http://m.sears.com/productdetails.do...r=00940774000P
And a feeler gauge for less than $10.
http://m.sears.com/productdetails.do...r=00940804000P
Lilpooh is offline
