300 Amp SPX series alternator! just ordered one, soon my charging issues are history - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-17-2012, 01:41 PM Thread Starter
juzatheman's Avatar
i have had my -03 Excursion about two years now and have all this time wonder why in the world the voltage never seems to go up 14v or little over it like evry other cars i have seen.
and i have seen some cars in past 15 years working as a car mechanic...
i have try to resolve the problem in evry possible ways i can think of without changing the factory setup.
(two new alt and two set of optima batterys and with normal batterys,new wiring and nothing helps and the list goes on what i have try)
there just are not enough amps coming from the stock alt what the truck needs!
soon i should have more than enough amps and no need to charge my batterys once a week when winter arrives to here north europe...
juzatheman is offline
post #2 of 17 Old 08-17-2012, 01:47 PM
ZMANN's Avatar
Quoted: 1576 Post(s)
if your at 14v now don't expect more
you will have more amps and more available at IDLE but you do not want to see huge voltage #'s that will cook a battery
We Miss you Ronnie
ZMANN is offline
post #3 of 17 Old 08-17-2012, 01:55 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
He is saying he doesn't get that voltage not that he wants more that that.
Sent from my SPH-L710 using AutoGuide.Com Free App
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #4 of 17 Old 08-17-2012, 01:57 PM
ZMANN's Avatar
mine doesn't go over 14 nor do I have a problem ?
We Miss you Ronnie
ZMANN is offline
post #5 of 17 Old 08-17-2012, 02:11 PM
Quoted: 15 Post(s)
Some system(I don't know if ours is) are temperature compensated. For me, the Optima batteries have not worked that well. Your voltage has to do with your regulator setting(not adjustable by normal means). Might I suggest the dual alternator setup that was a factory option. And as always with battery/charging systems make sure all connections are clean and tight, both positive and negative!
lenzhotrod is offline
post #6 of 17 Old 08-17-2012, 02:34 PM
ZMANN's Avatar
ford has a procedure to go from duals to a single ALT but they don't advise going from single to duals .. and I am not sure why? ,, but the dual to single requires a wire loom mod
maybe the harness not being set up for duals is the issue ?
We Miss you Ronnie
ZMANN is offline
post #7 of 17 Old 08-17-2012, 02:48 PM
Quoted: 15 Post(s)
Yea, and if I recall, it has some PCM program mods. Maybe not that simple after all. I have the dual setup, but it was factory orderd. Nothing is easy anymore.
post #8 of 17 Old 08-17-2012, 10:30 PM Thread Starter
juzatheman's Avatar
yes all positive and negative cabels has check and re check many times
even try with new cabels and extra cabels.
i can see almost 14v after 30mile drive when evry possible thing is off and rpm's around 2000
but cause i live in Finland and the weather is close to Alaska i think?
here is long and cold winters and it is allready some mornings like 40F or under couple of months and it drops to zero and from there -25F - -30'F
and i sure like to use lights heater and rear heater for kids
yesterday we came home and i let the truck idle couple of minutes the voltage was around 13.5 with noting on.
then i put all on what i can think of,
low and hi lights front and rear heater rear window heater ,radio, dvd push the brake and the voltage drops 11.8
and i dont like that at all. when i drive small and pitch black country roads i hate when let off the gas and push brake head lights dims and blower motor dims and when back to gas all brights up again...
im going to install webasto diesel heater to my truck and it use truck own heater motors to heat up the cabin so it will stress and drain the batterys 1/2 - 1 hour mornings before i start the truck so with my current situation it would be hope and dreams to try start the truck afer that.
post #9 of 17 Old 08-18-2012, 05:57 AM
southend's Avatar
If you dont upgrade the wiring, your asking for trouble.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #10 of 17 Old 08-18-2012, 06:09 AM
ZMANN's Avatar
this is where your new alternator will really benefit you ,, I think yours may be fine just overtaxed with everything on at IDLE
also you should not see your lights and blower dim when letting off the throttle your batteries shouldn't let a momentary drop in alternator voltage
impact the lights and fan so quickly in My opinion
We Miss you Ronnie
ZMANN is offline
