Where do I get the specialty fittings for testing? - Ford Powerstroke Diesel Forum
Old 08-17-2012, 07:05 AM
Where do I get the specialty fittings for testing the HPOP leaking, by connecting an air hose thru the IPC hole? Also, there is a special connection fitting for the IPR with two wires, that you hook 12V to to close the IPR for this test.
Also, the fuel pressure port out of the fuel filter. None of my fittings with my fuel pressure kit work, nor my friends Snap on set, or his older test set.
The local Ford dealer doesn't carry either of them. He thought maybe Rotunda who makes Ford tools.
Old 08-17-2012, 07:17 AM
Use an M12x1.5 to a #4JIC fitting for the air at the ICP location - any hydraulic shop should have one. You can order them from a lot of places on the internet.
To command the IPR valve - you can use an old ipr connector from an old harness wired to a cig. lighter plug and only keep it plugged in for 2 minutes not to damage the IPR. I have been told you really can go longer and not damage it, but I like to be conservative.
Try asking a tech at your local Ford dealer, maybe one will be nice enough to snip one off a harness thats laying around.
Red wire switched power Pin A B+; Yellow/red switched ground Pin B-
Also:
Without a scan tool to take active command of IPR duty to 100%, you can do it by having the key in the RUN position, and jumping pin #2 of C1381c (the middle of the three PCM connectors between the driver side battery and the inner driver side fender well which requires the battery cover removed to access) which will be a yellow wire with red stripe. This is the ground side wire to the IPR.
Lastly:
Tool to close the IPR:
Automotive Tool Web-site - DenLors Tools
OTC 6764 Ford Diesel 6.0L IPR Controller / Tester
Old 08-17-2012, 07:20 AM
Fuel Pressure adapter and hose (for remote location of the sending unit (install lower than the fuel filter bowl test port that it connects to).
M12x1.5 to 1/8" NPT fitting:
6.0L Fuel Pressure Adapter
Old 08-17-2012, 07:23 AM
Thank You Bismic!
