6.0 must do/haves - Ford Powerstroke Diesel Forum
Old 08-16-2012, 10:23 AM
6.0 must do/haves
New to the 6.0 2005 Excursion only mods are exhaust and air in take. Everything else stock. Plan on a SCT soon just for MPGs n towing ONLY not for speed. What basic mods should be done to help keep the 6.0 running good( besides regular oil changes, filters.....)It's my daily driver. Thanks
Old 08-16-2012, 11:48 AM
Feedback Score: 3 reviews
A monitor solution like DashBoss (iPhone/iPad/iTouch), Edge Insight CS/CTS, or ScangaugeII. Watching what's going on with your motor is the best/first mod you should do.
After you have checked the health of your motor, then determine where to spend your money. You may/or may not need to replace your oil cooler. If you do need to replace the oil cooler, then while it's apart, start the upgrades.
Old 08-16-2012, 11:51 AM
Someone post the links for him, I'm heading into work. No time! LOL!
Old 08-16-2012, 11:53 AM
Feedback Score: 5 reviews
Monitor (like said above) and a coolant filter is first
What links
Old 08-16-2012, 11:54 AM
First thing is coolant filter. Then check the health of your oil cooler with some gauges.
Old 08-16-2012, 12:40 PM
What about dash command for iPhone? I already had it.
Old 08-16-2012, 01:06 PM
The last I check about DashCommand is it didn't support all the PID'S for the 6.0, you would need to spend a bunch on money to watch everything that the already mentioned monitors can do for cheaper.
Here is some starting links.
Write Up: Monitoring the 6.0L PSD.
Write Up: Bullet-Proofing the 6.0L PSD.
Things to consider about owning a 6.0L
And if your interested in using a iPhone/iPad/iTouch for a monitor, then read this link. For $300 ($170 for DashBoss, $100 for EGT, $30 for Fuel psi) including external sensors like EGT and Fuel psi, you can watch everything needed for the 6.0. Or $170 without the external sensors, but I recommend getting EGT and Fuel psi. Any questions on DashBoss, let me know.
DashBoss monitoring review.
