Dash pod - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-16-2012, 08:26 AM Thread Starter
tylerb05's Avatar
Dash pod
What a waste the stickys didn't stick.
50 $ down the drain till I figure out how to get it to actually stick. Waste
Tyler.
03 f250 king ranch 4x4 6.0, 2.5 level with bilistein 5100s,04 KR Rims with Toyo open country 33/12.5/18s , GONE LOONEY , bully dog cold air intake, mbrp 4inch turbo back exhaust 5inch tip, edge insight cts w/ egt probe, sinister coolant filter,Updated hcfm plug Blue Spring, Rotella T6,10k headlights and fogs, EGR Gone, ELC
Upcoming:
W/M injection
Injectors
tylerb05 is offline
post #2 of 9 Old 08-16-2012, 09:00 AM
pcris's Avatar
So your saying the dash pod is worthless? Is that how it is attached to the dash, stuck on? I can't decide between the dash pod or pillar mount because both have their flaws and I'm picky.
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
Blue Spring | FP Gauge
PMM Coolant Filter
Leveled|35's
LED Reverse|Bed Rails
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #3 of 9 Old 08-16-2012, 09:51 AM
Razorsedge's Avatar
Mine stuck just fine. I cleaned the dash with alcohol, stuck the Velcro pieces on and let them sit for a bit then I stuck the dash pod on. It's been stuck just fine for almost a year now.
2005 F250 4x4 King Ranch 6.0
Two tone removed, Quad Captains, High idle mod
Edge Insight CS w/ EGT, fuel PSI, and turbo timer
4" turbo back straight pipe, Dieselsite coolant filter
BPD FICM, '03 turbo, IPR gen2 delete, Zerex ELC
Goodyear Duratracs, Tuned by Matt@Gearhead
Razorsedge is offline
post #4 of 9 Old 08-16-2012, 10:08 AM
RRF985's Avatar
Mine has been on for two years no issues. Did you clean the area before you applied the Velcro patches?
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #5 of 9 Old 08-16-2012, 10:54 AM
Chatham036's Avatar
Quoted: 145 Post(s)
i ended up getting loctite adhesive tape. it is similar to two sided tape, only there isnt the weird foam core. it is pure compound. holds like a rock. LoctiteŽ Power Grab Heavy Duty Adhesive Tape (1360350) - All-Purpose Glue - Ace Hardware
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #6 of 9 Old 08-16-2012, 05:15 PM
Aretoo's Avatar
I had the same problem. Mine never actually came off I just did not like how it felt up there. It never felt solid. I went to Lowes and got 4 binding posts and used them to secure the bracket to the dash and then used it to secure the pod to the metal bracket. The only down side is I had to drill 2 small holes in the dash, but since I plan on keeping the truck it should not be an issue and if I do have to take it off they can easily be filled with black epoxy. He are some pics to help make it more clear.
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
Sinister Coolant Filter
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #7 of 9 Old 08-17-2012, 09:43 AM
trophy_23's Avatar
I decided I liked the pillar pod and didn't even both with a dash pod. I got it when they had the rebate for the free dash pod, so I bought the CS with the pillar pod and installed it, then my vendor took the free dash pod back for credit when I got it in the mail. It was great.
Here is a pic, sorry it was a bit dark so crappy quality
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
post #8 of 9 Old 08-17-2012, 10:27 AM
pcris's Avatar
Daggon, I woulda gladly taken that dash pod off your hands. Did you mount it when you had it? I'm trying to get enough opinion about the two to choose between them. I realize you have the CS but still similar. I just can't decide which to get.
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
PMM Coolant Filter
Leveled|35's
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #9 of 9 Old 08-17-2012, 11:07 AM
trophy_23's Avatar
No I didnt install it, just returned it for credit. I didnt like the look of the dash pod and how it mounted.
High Idle
Duraflaps
Dually ID Bar
