Well I think it's time for head gaskets.. You guys think? - Ford Powerstroke Diesel Forum
Old 08-15-2012, 06:19 PM
Last Friday, same day my egr delete parts came in, my truck (mods in sig) it puked for its first time. So I I did egr delete and oil cooler over the weekend, the egr cooler wasn't bad. Long story short truck pukes any time I run it hard.
Today I got the truck up to temp then released degas bottle pressure and teed in a pressure gauge, took it for a drive and if I put a good load on it climbs to 15 psi pretty quick then gauge flutters as it vents.
Did I do this test right? I think there toast
Old 08-15-2012, 06:24 PM
Leaking head gaskets sound pretty likely.
With coolant temps at 195*F (100*F ambient), I get 9 psig typically. After venting mine and running it hard for 100 miles the most I see is 2 psig (normally 1 psig) and that is with the coolant at 205 degrees (coolant pressure will go up about 1 psi for every 8-10 degrees on a system w/ proper coolant level).
Old 08-15-2012, 06:30 PM
Come on! Your supposed to tell me I did the test wrong and there good!! Lol.
Thanks for the reply. Is that about the best way to know for sure or is there a better test. I did a search and that's where I got the pressure test from
Old 08-15-2012, 06:34 PM
You can also do a test for combustion gasses. Link is below.
DTS Articles - Detecting Combustion & EGR Leaks
Also, I can send you Ford's TSB on it of you wish. Just PM me an email address.
Old 08-15-2012, 07:11 PM
My coolant level was about 1/4 to 1/2 inch under min line. Started my drive at 192* and 0 psi. After a mile or so I got it to 200* and venting at 15 psi. Not lookin good!
Old 08-15-2012, 09:29 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Yeah sorry to say bud your head gaskets are toast.
