Water seperater stripped - Ford Powerstroke Diesel Forum
Old 08-15-2012, 09:12 AM
How do I get my water seperater off stripped. I just need to drain the water cause my wif light came on. I just need to drain it till my updated one comes in.. Any ideas
Old 08-15-2012, 09:14 AM
which plug do you have, one is a finger tight style that sticks out, the other is flush and uses a 6mm allen to remove, i believe both have the allen hole.
Old 08-15-2012, 09:17 AM
6mm Alan wrech tried unscrewing. But seems pretty stripped .
Old 08-15-2012, 09:52 AM
Some have tried JB weld ing the wrench to the plug. Some have had success, others have bought a new cover plate. Not much room in there.
If you have to get a new manifold plate, it isn't the same as a stock one for your 03. They eliminated the fuel heater.
6C3Z9B249A I think this is the right part#, please verify with your parts supplier.
Tousley Ford Parts:
Ford Parts - Tousley Ford Parts Depot
ebay: (I have zero knowledge of this seller, just showing for picture)
FORD 6.0 Diesel Manifold Service Kit HFCM 6C3Z-9B249-A | eBay
Old 08-15-2012, 09:57 AM
I just got the updated plug. Should be here any second now the problem
Is getting the old one off?
Old 08-15-2012, 09:59 AM
Easy out.easy out. Used them before.
Old 08-15-2012, 12:29 PM
Got it thanks
Old 08-17-2012, 04:02 AM
i was going to suggest trying a 7mm, or the equivelant standard size allen with some persuading to enter the stripped hole.
Old 08-17-2012, 10:26 AM
or a torx bit
Old 08-17-2012, 12:48 PM
MAD - Modification Addict
Feedback Score: 7 reviews
So how did you manage to get it out?
