Best 6.0 mods for MPG
My 07 has 74k and is out of warranty so i have decided to make some mods with the intention of better mpg.
1)What mod would giver the greatest increase in MPG 2) second best 3) 4) Thanks |
delete the emissions all together
run a high HP tune from a respected 6.0 tuner try to keep your foot out of it should see around 20 ish on the freeway. |
To go with a tune would mean studs for insurance right? best wishes B |
full tb exhaust, and a custom tuned SCT... dont forget your monitor/ gauges as well
we can set you up with anything you need if your interested -Raul |
double post...............
Don't spend lots of $$ searching for mileage. You will be disappointed. The other added benefits such as power and driveability are definitely worth the $$, but the mileage increases will be minimal at best.
If it does anything for power or fuel mileage, it would help it! If your state doesnt have inspections GET RID OF IT! Because when the system does fail (Which it will) you will be looking at some $$$$. As far as the tuner goes, you will get mixed reviews here. It all depends on how much self control you have. Some guys are reserved, use the chip for better MPG and slight increase in power, Others feel how MUCH power they now have,think they have a race truck and the pedal stays on the floorboard 90% of the time. With studs thats fine, but with TTYbolts, prepare to blow the gaskets. ![]() I would start with the basics..... Run a good fuel additive (Cetane booster) Change both fuel filters, and oil filter 1) EDGE CTS MONITOR or another monitor device 2) EGR delete 3) 4" turbo back exhaust 4) Upgraded fuel pressure spring from ford 5) SCT with custom tunes from one of the tuners of your choice. Adding a coolant filter wont help your MPG, but it seems to be very important on the 6.0 to keep the cooling system clean of debris. |
Slow down, and accelerate slowly. You will see the biggest gains with these
Here's my opinion on fuel mileage modifications:
1) A responsible right foot - free 2) Monitor package (Insight CS/CTS with EGT and Fuel Pressure) - $560-660 3) SCT X3 tuner with the highest HP file your trucks build can support (bolts ~400RWHP, studs ~440RWHP) ~$420 4) Free Flowing exhaust (3.5" DP, 4" CAT back - Cat optional) ~Varies. 5) FICM tuning (depending on build and head status) That will yield the best cost-benefit ratio with what I experienced. Reason for monitor above tunes - Fuel Pressure, Low FICM voltage, etc. all rob you of mileage, and may lead to bigger repair bills. If you're after fuel mileage, your out to save money, which means catching issues before they compound themselves. Last edited by colo_dually; 08-15-2012 at 11:57 AM. |
Or you could be really cool and spend that $1200-1500 on one of these VW golf 1986 diesel
