HEAD WORK WITH STUDS - Ford Powerstroke Diesel Forum
Old 08-15-2012, 08:00 AM
hey guys i'm doing studs and gaskets at my house, whats the spec on head work max milling, i heard .008. also can the heads be milled with the valves in the head. just want to make sure before i drop them off thats the guy knows what he's talking about.
Old 08-15-2012, 08:32 AM
up to .008 off deck
valve guide clearance .002-.0027
valve recession .013-.027 it is preferred by some to be .026-.030
valve height is 2.225-2.230 after milling
try to set @ 2.220 for proper lifter preload
Old 08-15-2012, 08:39 AM
thanks man, i'm hoping she dont need much she only has 68k on her
Old 08-15-2012, 09:47 AM
Only thing I can add is that you can take off as much as .010 as long as the head is at least 3.74" thick when you're done.
Old 08-17-2012, 04:50 AM
how bout the valves, do they have to come out
Old 08-17-2012, 06:27 AM
I had mine milled recently and only had to pull the rocker box off the head. valves were recessed enough that they werent a problem.
Old 08-17-2012, 06:32 AM
thats what i wanted to hear thanks
