boot connecting to intake elbow - Ford Powerstroke Diesel Forum
Old 10-14-2007, 01:46 PM
keeps blowing off...will spraying some white rain hairspray on the tube fix this or do i need a metal tube....isnt there a recall on this? any ideas will be appreciated....thanks...
Old 10-14-2007, 01:58 PM
DKR DKR is offline
<--Pro Cooler Racer
There is a TSB...be right back with a link.........
Edit: Does this work?
Intercooler Hose Blow-Off; Oil Leaks at Intercooler Hoses:
Some trucks may exhibit oil leakage from the hot side intercooler hoses. If one of the hot side intercooler hoses blow off it will cause the truck to exhibit a low power/low boost condition. Hot side intercooler tubes are no longer available as an assembly. Replacement hoses have a revised inner liner that has adhesive properties. Use the following parts as needed to service the condition:
Short upper hose, equal length elbow: 6C3Z-6C640-C; metal tube: single alternator 6C3Z-6K769-B or dual alternator 6C3Z-6K769-A.
Long upper hose, unequal length elbow: 6C3Z-6C640-A; metal tube: single alternator 5C3Z-6K769-AA or dual alternator 5C3Z-6K769-BA.
Use this hose and tube combination if the hose blows off
Clamps: upper hose 6C2Z-6K786-AA; lower hose to tube 6C3Z-6K786-CA; lower hose to intercooler 6C3Z-6K786-EA.
Lower hose, all: 6C3Z-6C640-B.
Clean the hose mating surfaces to ensure the hoses will stay in place. Seat the hoses completely onto their mounting surfaces before tightening the clamps to 9 ft/lbs. Undamaged hoses may be reused, but they must be cleaned and inspected. If the inside of the hose is blue, it is recommended to apply a thin uniform coating of Motorcraft TA-31 RTV silicone to the mounting surface after cleaning. After reeassembling, allow the silicone to cure for three hours before driving the truck. Test drive the truck while monitoring the boost pressures, which should be 22-25 PSI. An overboost condition will cause the hose to blow off.
TSB 07-5-15.
On 2004/05 trucks that exhibit the cold side hose/pipe blowing off at the intake manifold, replace the plastic tube with part #6C3Z-6C640-AA as in recall 05B29 (trucks built from 12-15-03 to 4-1-04), or repair as in TSB # 05-22-3 (trucks built from 4-1-05). Clean the intercooler and intake flange with brake parts cleaner. Seat the hose/pipe onto the intake manifold and torque the clamp to 9 ft/lbs (12 NM). Broadcast Message 1329, TSB 04-20-9, TSB 05-22-3.
Old 10-14-2007, 02:03 PM
so ford will have to replace it right? will they gie me the metal one..
Old 10-14-2007, 02:09 PM
DKR DKR is offline
<--Pro Cooler Racer
If I understand it right...if it is a TSB and the problem is actually happening, yes they pay. The parts listed is what they are supposed to use, so if I read the TSB right, that is what you should get.
Old 10-14-2007, 02:17 PM
thanks for your help...it happened 2 times when it was stock....and that was about 10,000 miles ago and it just happened again today....i have the cfm now they wont give me crap bout that will they....
Old 10-14-2007, 02:22 PM
DKR DKR is offline
<--Pro Cooler Racer
I would guess it all depends on the dealer. Wish there was a straight answer.
Old 10-14-2007, 02:34 PM
ok thanks...i just took the tube off wiped it clean and tried the hairspray....
Old 10-14-2007, 02:37 PM
DKR DKR is offline
<--Pro Cooler Racer
Sure thing....
Worth a shot! Let us know if it stays this time around.
Old 10-14-2007, 02:43 PM
will do....
Old 10-15-2007, 05:47 PM
i didnt work....it keeps poping off on anything above 20 psi......
