Is this normal??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-14-2012, 12:01 PM Thread Starter
smokeum99ta's Avatar
Is this normal???
So the other day I replaced my ball joints. Today I decided to check and see if my four wheel is working. Seems to be fine but as soon as I turn the knob to 4x4 the ac no longer came out of the vents only the defrost. I don't remember it being like that before but rarely use 4x4. Any ideas?
smokeum99ta is offline
post #2 of 6 Old 08-14-2012, 12:29 PM
taskforcefreddy's Avatar
I can't give you an exact readon for this but I know that the auto-locking hubs are operated via vaccuum lines which is also what actuates some of your AC/Heater controls. Check your vaccuum lines to make sure they're all connected.
taskforcefreddy is offline
post #3 of 6 Old 08-14-2012, 12:35 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
^^^ what he said
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #4 of 6 Old 08-14-2012, 12:44 PM
Quoted: 15 Post(s)
Yes, look for a leak in the vacuum system or components. If those test good, check the vacuum pump it self.
lenzhotrod is offline
post #5 of 6 Old 08-14-2012, 02:49 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Yep, vacuum leak. One of the first things to check is the gray vacuum line that should be either connected to the inline heater hose valve or to a stud in front of the HVAC box. This line tends to get knocked off by accident.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 6 Old 08-14-2012, 04:19 PM Thread Starter
Thanks everyone. I figured a vacuum leak as well but didnt have a clue where to start because the heater controls have a zillion lines. I'll check that heater line as well.
