Tricks or tips to get the exhaust y pipe to line up to the turbo
So i just replaced the EGR and oil cooler in my 05 f350. Got it all back together and i have aloud whistle that gets worse when you accelerate other than that the trucks runs and sound great. After reading many posts it confirmed what i thought it was the y pipe to the turbo leak. When i removed the turbo there was a small soot patch from it leaking before. SO i went and purchased a new clamp for the install.
So the leak is still there only worse. Does anyone have any advice or tips on how to align the turbo and y pipe. Thank you any help is appreciated. Dustin |
I had the exact same problem when doing my egr delete. take the nuts and bolts loose from where the y pipes connect to the manifolds, then line up and snug down the y pipe to the turbo, then tighten up the manifold to y pipe bolts. its a pain in the a$$ to get to the manifold bolts on the drivers side, on the pass. side just remove the inner fender. You'll probably need another guy to help.
They can be a PIA. Sometimes I swear I spend as much time chasing a leak as the repair took and other times it will all just fall in place. That is one of the few times you wish you were working on a van!
What I did was super easy and can be done with 1 person. I just used a pull strap and hook 1 end hook to the Y pipe and the other hook to the front horse collar. Then I just pulled the strap tight and it pulled the Y pipe right up tight to the turbo. Super easy and Ive done it a few times with no problems...
pull/ratchet strap works great. i had the same problem when i did a turbo cleaning. put the ratchet strap around the ypipe, laid a towel over the top of the passenger fender and went down to the passenger front whell with the other end. easy.
Just wanted to say thank you for all the help. I used the ratchet strap and pulled everything right together, took 20 minutes!!!!!!
