Oil in my intake, a little help please
A little back ground first.
2005 Crew cab, got her a month ago, had issues with white smoke, and bucking/ missing feeling around 55mph, so I started doing some reading on the site and decided to start bullet proofing my 6.0. So far I ordered a blue spring kit from my local ford hookup, and plan on ordering sinister egr delete this week. Today when I did my blue spring update, I removed the inercooler piping that goes from the intercooler to the intake, after I removed it I found oil sitting in the piping coupler both where it meets the inner cooler and right behind the fan shroud. I did some searching on the site http://http://www.powerstroke.org/fo...ak-thread.html and saw that somebody with an oil leak mentioned An inercooler line. Has anybody had this problem? |
It's normal because the crankcase vents into the intake. If you want to eliminate the oil in your intake you need to research the CCV mod.
Normal
Thanks guys, it's. My first diesel and didn't know. I appreciate the help and quick response.
| Tags |
| oil intake iner cooler |
