What would you do? - Ford Powerstroke Diesel Forum
post #1 of 40 Old 08-12-2012, 07:18 PM Thread Starter
What would you do?
I posted some background in the diesel diagnostics forum (thread name: NEW OWNER, ANYTHING I CAN AVOID) but here is to catch everyone up.
I recently bought a 2005 CCSB lariat with 138K on it. I assumed the truck was 100% stock and it seems to be using a bit of coolant. I ordered a bunch of stuff ARP's, EGR cooler, etc etc. basically my plan WAS to bulletproof it. I am stationed in Georgia and my wife took the truck to Indiana because her father's health is deteriorating, about a week after I got it, so I didn't get much time to check it out. Wife stopped twice to refill the degas bottle, she never overheated it, but she said it got past 1/2 way on the gauge and she pulled over around 3/4 on the gauge to top it off (that's how I found out it was using coolant)
Anyways I am now in Indiana as well, and I was looking at the truck today during a coolant flush, and to my surprise the truck already has ARP head studs, I am unsure of the head gaskets, it already has an EGR delete, and I think it also has a bulletproof FICM.
I will post up some pics tomorrow in the daylight and you guys can let me know what you think of everything.
Also there is NO check engine light on (and it's an 05) so it must have already been flashed because the EGR valve is missing with a block off plate installed and the plug that connects to it is just there not plugged into anything.
I want to get an SCT tuner, and a FICM flash but at this point I have NO IDEA what has been done to this truck. I called the previous owner he claims he has never done anything to the truck except replaced the water pump about a month before he traded it in on a brand new ford diesel. Also the Coolant hose that I think runs to the EGR cooler, is a metal tube bent at around 135* angle(more than 90* but less than 180*) and there is a blue silicone hose that apparently is bypassing where the EGR cooler would have been.
Armed with this new information I am looking for a small coolant leak (hoping it's just a leak) because the truck doesn't smoke at all, but it could very well have had a headgasket job using black onyx gaskets.
My thing is I don't want to go flashing the PCIM and FICM if it is already flashed. So my questions is this: What would you do?
I will take pics and look at anything you all suggest so we (you all, and myself) can try to figure out what has been upgraded, what needs attention, and what should be left alone. Thanks for reading, and thanks for your help and suggestions.
05 Lariat Crew Cab, Short Bed, 142K and counting, 4x4, ARP studs, EGR Delete, IPR High Flow Coolant Filter, Dash Boss, SCT SF3 innovative tunes, Innovative FICM Tuner, Deleted CAT and Muffler, blue spring upgrade, High idle mod, Cobra 29 LXE.
turbocharged is offline
post #2 of 40 Old 08-12-2012, 07:23 PM
2003kingranch's Avatar
If it were HG it would not be using coolant. Its not puking is it? how much coolant is it using? Does the truck smell like coolant at all? if there is no cel it may be tuned. because a 05+ truck will need sct tunes to disable the cel with an egr delete
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #3 of 40 Old 08-12-2012, 07:27 PM
-IMO I would check the PSI of the cooling system to see if their is an issue with HG's.
-Get something to monitor your vitals with, I didnt see you mention anything about that
-Get it re-flashed at ford and then do what you want with it.
IMO thats a good place to start with
06 F-250 Lariat
-ARP's
-EGR Delete w/ up-pipe
-Updated stand pipes, dummy plugs
-6.4 Banjo's
-175cc injectors over stock nozel
-SCT X3 w/ SRL
-PMM Coolant Filter
-Edge CTS
-Leveling Kit
-35's
-OEM 20's
-Blue Spring Update
-AEM CAI
-CAT EC-1
-Rotella T6
-Straight Pipes
wagner22 is offline
post #4 of 40 Old 08-12-2012, 07:57 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Hey bud glad to hear its mostly been bulletproofed. Sounds to me you have a possible coolant leak. Now that said if its not puking it can use coolant with blown head gaskets because when the system is under pressure if the gaskets have failed it could leak back into the cylinders after the truck is shut off.
What you want to do is get a pressure gauge on the cooling system and get it up to temp and release the pressure in the system by loosening the degass cap. Be careful not to burn yourself. Retighten the degass cap and see if you can get a spike or rise in the system. Once it's pressurized park the truck and shut it off. Let it sit for about a half hour and check the pressure on the gauge. If it has stayed the same as when you shut it off then you don't have a leak. However if the pressure has dropped significantly then start searching for leaks everywhere possible. If none are visible outside of the engine than you likely have either blown head gaskets or possibly cracked heads.
Try this test and let us know what happens.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 40 Old 08-12-2012, 08:04 PM Thread Starter
@wagner22 you reminded me, I have a dashboss on the way since I have an ipod touch that I don't use anyway.
These are the things I bought and are on there way, (bought them in georgia before I got here to see the truck)
IPR Research: high flow coolant filter, ARP head studs, OEM headgaskets, Extreme duty EGR cooler, OEM Oil Cooler, HPOP fitting update kit, Blue spring update, Dummy plugs, I think that is it from IPR
MISC: Dashboss W/EGT probe, Innovative Diesel FICM tuner
The stuff I will most likely keep: Dashboss w/EGT, FICM tuner, Blue spring upgrade, Coolant filter, and most likely the OEM headgaskets (can the APR nuts/studs be reused?)
I also had in my cart a bulletproof FICM, and an SCT tuner, but had to wait on those, I am in a time crunch right now, I am here for 14 more days, then I have to report back in to Ga. so I will be driving the truck back down there, then if need be I can park it and work on it/bulletproof it at my liesure.
The truck does smell like a HINT of burning coolant, but only when you shut it off and walk in FRONT of the truck, maybe it's just leaking onto something hot and burning off from there. There is ZERO smoke, and Zero smell in the exhaust.
Wife says she added 2 to 2.5 gallons of water to get from Ga. to In. (approximately 1,000 miles one way) She let her brother take it for a drive and he romped on it a bit and said it was leaking from the de gas cap. I got here and confirmed the truck did in fact have an 18psi cap on it, instead of the stock 16psi. I replaced that cap with a 16 pounder from advance auto, and removed the T-stat, filled it with some PEAK radiator flush (that's the only brand they had today) and per the instructions drove it around for approximately 1 hour, (instructions say drive for 3-6 hours and it can be spread out over a few days) truck never got hot, and doesn't appear to be spitting or leaking from the cap right now.
I have to go to town (20 minutes away) tomorrow, to get some coolant, and I will look for the test strips AND a pressure gauge and check the cooling system out both ways. I will also get some pics posted of the items in question. THX again
post #6 of 40 Old 08-12-2012, 08:44 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Your arps can be reused. Pm me a price on the new ones shipped to 44615 if you decide to sell them as well as if you decide to sell the ipr coolant filter and OEM gaskets.
DIY Cooling System Pressure Test Write-up.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 40 Old 08-13-2012, 07:28 AM Thread Starter
@tuscany I appreciate your help, I know how frusterating it can be to answer the same post 100 times, by 100 different noobs, none the less thanks for the patience. I will give you first dibs on the excess parts.
I will be going to get coolant and the pressure gauge and test strips, after that the truck should be dry as it rained last night. Once i get back from that running around I will start posting pictures of misc parts and see what you guys think the next course of action should be.
Should have all my parts by the end of this week. (hopefully)
post #8 of 40 Old 08-13-2012, 07:41 AM Thread Starter
I was worrying that it could be leaking into the cylinders as well, but when I got here it had been sitting for a few days, I went to the truck and cranked it up, it cranked a tad bit slower than I remember, fired right up(about 2 seconds) and it still didn't smoke at all, so hopefully all this is pointing to an external leak.
I got a new cap as the one that was on there was RATED 18PSI. It has a new stock one on it now, but does anyone think that extra 2PSI of pressure could do some harm? I am not talking about 2PSI for a quick ride around the block, I mean extra 2PSI for a solid month. maybe over time the extra pressure may tear up something.
I personally think it would be fine, but you guys are the collective experts here. THX
post #9 of 40 Old 08-13-2012, 09:19 AM
Not sure if you know this or not, but the with engine cold, the coolant level should be at the MIN line not full. Maybe it was overfilled and thats why you were puking ?
06 F-250 Lariat
-ARP's
-6.4 Banjo's
-SCT X3 w/ SRL
-PMM Coolant Filter
-Edge CTS
-Leveling Kit
-35's
-OEM 20's
-Blue Spring Update
-AEM CAI
-CAT EC-1
-Rotella T6
-Straight Pipes
wagner22 is offline
post #10 of 40 Old 08-13-2012, 09:28 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
doesnt sound to be a terrible problem id say is external and only leaks under pressure and maybe only leaks when motor is hot suggesting a leak that gets worse as things expand.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
